RTX 3060Ti Aero alternative? Meet the DIY PALIT StormX 3060Ti ITX Edition
AMv8-1day
220
187
I'm researching SFX cases and I found this Peeress Rider R2.
It is aesthetically good, fairly cheap and minimal liter.
I'm currently looking at the Densium 4...
It's wooden front plate makes it pretty attractive, and would seem to meet your needs.
Reactions: Valantar
noobita
today I completed my mod with a DIY backplate - nothing fancy, just for protection
I doubt it will help anything but I also put some thermal pads behind the area of the VRMs
next up I will move the card in my MIT1 build and see how it performs there...
PS: as you can see, I made two of those backplates. If someone is going to replicate this mod and should need one - just let me know.
edit: here are the test results with the backplate - a little bit cooler but this could also be the weather today
Hi, how di you make that backplate? Is it made of metal?
oasis1991
57
37
those are solid caps - they usually don't get that hot and with the PALIT cooler mod you can probably get away with cooling them only by the airflow the fan is pushing against them
hey, i have stupid question
but now my rtx a4000 has audible coil whine while idling (like annoying level since it is louder than the gpu fan at 1000 rpm)
definitely not 7660b coil whine i am sure
is it possible that becasue i didnt cool those solid caps properly thus make them whining?
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
As the name suggests, coil whine comes from high frequency vibrations inside the coils (inductors) not caps. But you can try to apply some thermal pads to caps and inductors and see if it dampens the noise a bit.
Neathdrawls
235
420
what about 3060ti Colorful mini?
What about it? The 3060 and 3060ti from Colorful are already ITX sized.
You can check out the teardown over here. 4 heatpipes, but the closed up design of the card does affect the temperatures, according to users, but it is generally fine.
Based on the link’s pictures, Colorful also uses a custom PCB design for their cards, which the StormX cooler might not fit without dremeling.
To my knowledge, there are no listings for Colorful’s coolers as well.
Reactions: george5
Oizon
37
Saw interesting stuff in reddit today
Single Fan RTX 3070 mod
TLDR: not really worth hassle
- had to get broken rtx 3060 pheonix to use its heastink
- it is 2.5 slot so it is not relevant in conventional case anyway
- Asus RTX 3070 SI is hard to get
From what i see is
our Palit/PNY RTX 3060 heatsink would fit on reference pcb of RTX 3070
it just need to install some additional thermal pads on some areas
but cooling wise? definitely need undervolt
An interesting mod. That guy says he is using that phoenix cooler which is just taller than StormX cooler as I understood. That Phoenix cooler seem to have 3 heatpipes just like StormX. I wonder if that "tallness" does actually make much difference... Also I know that 3060ti coolers come with 4 heatpipes. Not sure how tall they are but most likely same as StormX. I hope someone would test some of these coolers for the community 😁
AMv8-1day
220
187
So to be clear, all branded A4000's are using identical reference designs right? They'd all line up with the Palit cooler?
ChinStrap
177
154
@REVOCCASES Thank you for this content/thread. Tonight I completed my 3060 TI ITX Custom. I rescued an OEM Dell 3060 TI from the mines on eBay for $285, and paired it with the PNY ITX version of the single fan cooler / also from eBay ($54 shipped). While the PNY version of the cooler is actually louder vs. the stock Dell twin fan cooler, temps are not that different. I'm pretty happy with this thing so far, I'll be even happier once it's home in my Velka 3. Thank you again for the inspiration.
Runamok81
Runner of Moks
Jul 27, 2015
443
609
troywitthoeft.com
Rebuilt my 4.2L PC from 2014 with a DIY 3060Ti. Fantastic mod!
slowboytommy
What kind of temperature are you getting? I modded my OEM Dell 3060 Ti with the Palit cooler and getting 80C full load. The problem is my hotspot temp jump all the way to 95c - 100c. Is this normal?
slowboytommy
Also, the included mounting screw are quick long. Is this a problem of inadequate mounting pressure?
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Already replied to you on Reddit. 100C hot spot seems a bit high. My card stays well below 90C. I'd check if the cooler makes good contact with the die and memory / VRM chips. Maybe you also need to set a custom fan curve for your DELL OEM card.
Reactions: slowboytommy
slowboytommy
One more question: do I need thermal pads for these? The old cooler came with pad that I couldn't remove without destroying them, so I left it without pads.
