RTX 3060Ti Aero alternative? Meet the DIY PALIT StormX 3060Ti ITX Edition
Moncavo
66
40
256
Mine just arrived yesterday, hoping to get some time in the coming week or so to fit it, and do my RCC-MIT1 build
Runamok81
Runner of Moks
Jul 27, 2015
443
609
troywitthoeft.com
Congrats @Moncavo and @SFFMunkee!
It sure has been fun going this route!
My DIY ITX A4000 build log = https://smallformfactor.net/forum/t...ming-pc-build-5800x3d-custom-a4000-gpu.17572/
Moncavo
66
40
Congratulations to these fuckers.
They refunded my purchase because ''out of stock'' when they had.
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
I'll spend more time with Afterburner. I'm not sure if I should expect power limit or voltage to unlock?
hey @Runamok81 - awesome build you put together with the modded A4000!
In your log you mentioned a "special Afterburner Version" - now I'm curious if you somehow succeeded to unlock the voltage slider in the meantime...?
I'm currently on Afterburner V4.6.4 with my A2000 and everything works fine, except for the voltage slider.
Runamok81
Runner of Moks
Jul 27, 2015
443
609
troywitthoeft.com
Hey, I've got a spare.
No, voltage was never unlocked. But, overclocking GPU and RAM yes.
I haven't tried other versions of afterburner, but I presume that OC doesn't work on those?
Reactions: REVOCCASES
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Over- and underclocking works fine for me (Afterburner V4.6.4, A2000, Driver 511.79). Also setting custom fan curve and power limits. Only the core voltage slider is grayed out.
Reactions: Runamok81
robbee
n3rdware
760
1,099
How about when you press CTRL+F is Afterburner, do you get the interface to set a custom voltage curve?
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
yes, that works fine. I can set a custom frequency / voltage curve to force the card running e.g. at 700mV up to a certain clock speed (around 1500 Mhz) - but I can't actually under- or overvolt like a "normal" RTX card.
oasis1991
57
37
@REVOCCASES could i ask your a favour?
next time when you tear down the gpu
coudl you measure the thermal pads thickness?
i tried to google it but i only found teardown image
my heatsink arrived with some missing thermal pads
256
thank you
i just need roughly estimate
but if you have caliper im happy with that too
Sorry for the delay getting this for you; but I hope this helps!
All of the thermal pads on my (Palit-branded) 3060 heatsink are 2.0mm, except for the long strip for VRMs or whatever it is, which is 1.0mm. ::EDIT:: Measurements were made with random el-cheapo digital calipers.
Please refer to the image below for reference. Ignore the wet looking cold plate, I’d just cleaned it with an alcohol wipe.
oasis1991
57
37
my a4000 might need another extra pad to cool these five inductors
but im not sure if placing thermal pad on the fin stack would help disapate any heat or not
thank you so much
Reactions: SFFMunkee
