thank you sirthose are solid caps - they usually don't get that hot and with the PALIT cooler mod you can probably get away with cooling them only by the airflow the fan is pushing against them
for information
This measurement is the same as the dual version from Palit?Sorry for the delay getting this for you; but I hope this helps!
All of the thermal pads on my (Palit-branded) 3060 heatsink are 2.0mm, except for the long strip for VRMs or whatever it is, which is 1.0mm. ::EDIT:: Measurements were made with random el-cheapo digital calipers.
Please refer to the image below for reference. Ignore the wet looking cold plate, I’d just cleaned it with an alcohol wipe.
Mine is the PNY “Uprising” dual fan 3060Ti and the thermal pads match. The screws didn’t, though, and neither did the IO plate mount. I’ll throw some pics up later when I rememberThis measurement is the same as the dual version from Palit?
Can't see why not, they might be a bastard to remove though.Can I reuse the thermal pads from dual version to single version?
Could you get the length of the pads?Sorry for the delay getting this for you; but I hope this helps!
Should be relatively easy to get from the images tbh. Now it’s installed and packed away I’m not sure I want to pull it back out.Could you get the length of the pads?
I finally got this one from Ali Express, hope has stock.
50.73US $ 11% de desconto|Fã do dissipador de calor da placa gráfica de fd10015h12s para páit rtx 3060 stormx oc 12gb|Ventiladores e resfriadores| - AliExpress
Compre Fácil, Viva Melhor! Aliexpress.compt.aliexpress.com
I finally decided to put my images here.
Yes. My plan is to get the vertical sfx cases, like aklla a3/a5 or k39 + enhace's psu flex. My best one is the sixge k3s, this has sfx support. Or the Sixge k2s for flex.Nicely done, are you planning on putting it in another case? The original fits in the Ghost easily.
I'm researching SFX cases and I found this Peeress Rider R2.Nicely done, are you planning on putting it in another case? The original fits in the Ghost easily.
It is aesthetically good, fairly cheap and minimal liter.
