Prototype REVOCCASES RCC-BIG560 | custom BTO case | maximum flexibility for high end hardware in <20L
teodoro
109
77
does the 142.9mm cpu cooler clearance figure account for the side bracket (without fans)? that is, can a c14s be installed with both a top and a bottom fan at the same time as a second 140mm on the side bracket?
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
The side bracket will deduct another 2mm - so in theory it leaves about 140.9mm. But let me check first and confirm with my prototype on Monday. Maybe I can make a "half side bracket" to fit the C14S.
Reactions: teodoro
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
I measured again... Cooler clearance from top of the CPU IHS: with side fan bracket: 139mm / without: 144mm
So with the side fan bracket a 25mm top mounted fan on the C14S does not fit. Without the side fan bracket it fits fine. But like I said, there is the possibility to make a "half-side-bracket".
Speaking of brackets, here is another one if someone need a lot of 2.5" drives:
Reactions: teodoro
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
As promised, I have uploaded a DIY-friendly edition here on the forum. Note that this version is a bit different from the one I officially sell (e.g. no brackets, etc...).
If you know how to use a CAD program, you can also use that for checking part compatibility / clearance.
Reactions: robbee and Arboreal
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
3,104
4,593
46
France
guilleacoustic.wordpress.com
AWESOME !!!!
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
2nd pre-order production status update:
  • raw material came in and I made another prototype to check assembly
  • @Goatee got the very first prototype I made earlier and he provided some helpful feedback
  • I send one prototype to my anodizing supplier for a test run
based on the prototype feedback and the latest prototype I will make a few minor changes:
  • the two additional PCIe slot cutouts were supposed to be cut away DIY if required -- I will now use normal PCIe slot covers instead
  • the new vent pattern makes the left and right panels less rigid compared to the old vent pattern -- I will slightly modify those panels
Goatee
739
1,513
Here are some pictures:
Top view, showing 2x noctua 140mms exhausting heat out the top
Side view, plenty of ventilation
Alternative side view / rear view. No i/o o 60mm fans fitted just plenty of room to breathe
The 3090 flow through cooler sucks cold air in from the bottom, exhausting it up / out the back of the case
Plenty of room to tie cables down / manage them on the utility plate next to the PSU.
Overall the case fits a 3090 FE in really easily, is really nice to build in (taking the struts out / sliding a panel in is dead easy).
Im using a really small MATX board, but the RTX 3090FE fits even with it being in the 2nd slot.
This is prototype is un-annodised, so fingerprints are possible but overall im really impressed and looking forward to the first batch with all the improvements.
Elaman
157
119
Oh man I love this build. Is this power supply really able to deal with the 3090, or is it just for the laughs?
Anyway love the circle pattern as well, wanna see more builds on this one!
Goatee
739
1,513
It’s in a mining configuration, so the 3090 is undervolted / underclocked on the core. Pulls 300w at the wall so the 450 is fine for this use.
wizard
anyway I could convince you to make one that has an extra 30mm in height 15 on top and 15 on the bottom to handle 45mm thick rads?
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
@REVOCCASES
I've missed the 1st preorder - would you know already when you will be taking second batch of preorders? Love the traditional layout!
If there is still interest from the community I will open pre-orders for a second batch after the first one has been delivered.
I could make a customized version for you but let me finish the orders for the "normal" version first. Why not try to go for triple 30mm rads in the current version?
Reactions: Arboreal
