Cooling Quick hands on the Cryorig Cu C7
Hudzzy
25
27
His automatic message on Ali Wang Wang says "i'm busy painting, i'll answer later" - all I can imagine in my head is some lonely guy in a small dark room busy painting away these little CPU coolers :D
Haha - most likely that's true, this guy is known for coating coolers with graphene. You can check his works on other coolers here:http://tieba.baidu.com/p/5057558284?red_tag=w2863019388
and his charge is pretty reasonable, 50 CNY for small & single towered cooler and 100 CNY for twin-tower like D15. The coating works better with larger coolers which has more surface, some customers claim even 10+C drop with it.
tinyitx
2,273
2,334
Yes, his charge is reasonable for labour and parts included. I imagine, he has done a lot of the spraying and so he has accumulated enough experience to do a nice job. Aesehetics is just important as the thermal.
Reactions: Hudzzy
Hudzzy
25
27
Kudos, and I'll redo all my testings with controlled factors, both coolers (coated alu c7 and coated cu c7, both using Noctua A9x14, manually set to max fan speed) will be tested later today in same ambient room temp, all other factors will be constant (voltage, speed, testing software, paste etc,.) except the cooler. With and without side panels. Hope I can contribute something to the community :D
Reactions: InfernoZeus
Fenrir
24
I am so happy I managed to buy myself one of the graphene coated coolers before he changed the price. I had two options: wait a week for payday or use my mastercard for once, and it looks like the going for the latter has paid off :D
IntoxicatedPuma
Customizer of Titles
992
1,272
I literally was an hour too late, I went to order at 5pm, got distracted, went back at 6pm and saw the price.....
Dedaciai
42
A couple of comments/questions:
- Great to see the C7 CU finally pop up. I thought it was going to be vaporware. And, can't wait till there are some good side-by-side comparisons with the LP53.
- Also anyone know where we can buy this graphene paint? I'd be completely OK with painting my LP53 myself if it means I can drop a few degrees C.
tinyitx
2,273
2,334
Get it from Grey Whale @ Taobao. 50ml for a small cooler and 100ml for a large cooler.
https://shop112115647.world.taobao....4.w5842-17844727016.2.1fe67206LoyBIT&search=y
An airbrush is suggested to achieve an even thickness and smooth coating, I suppose. Afterall, you want it to look great.
Also, I think I remember reading this Grey Whale guy mentioning that it is better for the coating be applied to a very clean heatsink (preferably when it is still brand new) because any dirt, dust, oil or oxidation on the surface will not allow the coating to stick well. So, be sure you clean your LP53 thoroughly before the application.
Good luck and be sure to report back.
Reactions: Dedaciai
loader963
666
571
Dumb question but does anyone have an idea about whether or when this will come to an online store with English as an option. I would much prefer to buy where I can at least read it lol.
tinyitx
2,273
2,334
Well, Prince William's son is learning Chinese and so is Trump's granddaughter. Maybe you can start to learn too. Never too late. lol.
OK, more seriously, may I suggest Google Translate. It is not perfect but it can get you by many times. Also, I bet the seller can speak English well in case you need to contact him directly.
loader963
666
571
I know, I know, just used to amazon and eBay. Got some time to think about it til the prices get back in line I guess.
IntoxicatedPuma
992
1,272
Sorry for hijacking....@hudzzy
