Here is the near final version of the case design. It shows a set up with a Thin Mini ITX board with discrete GPU, and two 2.5" HDDs/SSDs. The front panel shown is blank but more likely it will come standard with front USB ports (shown in the other drawings)
I've been going back and forth with different ideas on how to mount the SSDs, and decided that the simplest way for this case was to have the mounting holes directly integrated into the 3D printed shell. They're at 90 degrees with respect to each other so that the CPU cooler is allowed to breathe in fresh air more easily from above.
About the vents, I know that these vents are different from the circular vents I used in previous renders. But I decided to change them to harder edge slots as they fit better with the more angled look of the final design. They also ended up costing a bit cheaper to cut with laser.
Some ortho and iso views of the case. These show the front USB and audio ports installed in the front panel. This front panel setup is based on actual front panel board, which I have orderd a few of. These can be pre-installed for the case.
