I have assembled four sides of the case and, with a motherboard installed, it feels more solid. Still need to re-order the new bottom panels for it, especially since all the other units will be sold.
Now for the fun stuff- building a complete system in it. With the just a thin Mini ITX motherboard and blower CPU cooler, it feels sturdy enough to hold in your hands or stand on its own. I did some strength testing with the frame, by setting the case upside down.
There's no noticeable bending in the standoffs in this 3D printed frame, or any wobbling. The screws thread into the material very well. This also shows the advantage of having the standoffs separate from the bottom panel. You can easily install backplates for your CPU cooler, or an m.2 drive if supported, without removing the entire system.
Side and top view shots of the case with motherboard and cooler....
I left the paper backing on the gloss side on for most of the panels as I didn't want to completely smudge them until I test parts thoroughly.
I took it back to my desk and plugged the SSD back in. It's currently running GPU-less right now but that's a matter that I'm still working out. There's still lots to do to make sure this case is as user friendly as possible so there are still potential improvements. However it runs very cool and quiet especially with the top lid closed.
Now for some important stuff about the case and future production...
My observations and issues encountered so far:
- Installing an SSD directly onto the mounting holes is not impossible, but I found it rather cumbersome to put your hand in and around it to prop it up as you screw it on.
- I will design a SSD tray to ease installation, that can still fit around the frame. As usual, you screw the SSDs onto the tray, then the tray to the case. The tray will sit flush to the top, with countersunk holes for screws.
- For my own case, this will be made of a thin 1.6mm derlin (acetal) sheet.
- For future production cases, the frame will be updated to support thicker 3mm acrylic.
- The hole for the power switch is a tad too small, meaning you need to apply quite a bit of pressure to push it through, or attempt threading it using the switch itself. Holes need to be filed or enlarged. However...
- I may forgo the idea to use vandal-style switches altogether. I'm thinking either a custom made 3D printed switch like what @K888D uses for his LZ7 case, or a capacitive sensor switch with a label engraved on the panel.
- Either of these options I will want a switch that is pre-soldered on a breakout board to make wiring a lot simpler.
- The ASL GTX 1050 and 1050 Ti cards are probably the longest cards that'll fit in this case and they need a bit of work to install.
- You'll need to unscrew the I/O bracket and then replace it as the card needs to be inserted separately.
- Shorter cards (~170mm) shouldn't have this issue and won't need to have the bracket removed.
- The front PCB I/O panel fits, but just barely. The USB cables run into the motherboard and it's definitely going to be too much of a hassle to run these cables through.
- I'll either just supply a blank (no I/O) front panel, or one supporting just one or two USB 2.0 connections on the front.
Notes for producing these cases:
- Incremental updates like ones suggested above can be done more immediately with changes to the 3D printed frame. While bulk discounts are not possible for 3D printing, it has the side benefit of being able to iterate more frequently for case improvements.
- Different colors are not out of the question, especially if I could sell several more (5+) cases. The most straightforward to produce will be white panels with white frame. I would also like to offer clear side panels for flashier case builds.
- Currently, the most cost effective way to produce these panels is for 5 cases at a time unless I come up with a more efficient part layout.
- A PCIe riser will not come standard with the case. That will be a separate cost. I may offer this as an option to purchase, estimate about $30 for a 4x riser with this case.
- As vandal-style switches may be discarded for the final production model, the new switches will be built-in as part of the case.
- Standard cases will be sold in one solid color. Additional custom color/clear side panels will cost extra.
- By default, the front side exterior will be gloss, and all other sides matte.
- Currently I am not considering to try other vent patterns, but custom ones may be an option.
- All the screws for the case will be M3 hex screws, except for a few 6-32 screws on the back (for panel replacement) and standard motherboard screws. Hex keys will be provided for them.
- Packaging? I don't know if I'm going to ship in plain boxes or get a bit fancier by using custom graphics. Well, that's still something in the backburner, I haven't even given this case a proper name
There's still a lot of work to be done in testing out parts and compatibility with the case. The frame I received to build this case isn't perfect, and will need to figure out the kinks more as continue.
