Starting 10/27/2017 I began all the computer aided design work using FreeCad, an amazing if quirky tool that's still essentially in apha - and totally free. About a week before that date, I was doodling in class, running off 5 hours of sleep and a Dr. Pepper, when the basic design of the front plate struck me. From there I spent a few days just roughing out the design, thinking about what I would want out of a case.
Of course, that meant a low volume, high efficiency factor design. I really wanted to use the aesthetic functionally, and so I did just that. The ITX Tray slots into the front panel, and mounts to the back with mod cubes. The top and bottom panels are vented in order to allow airflow to move directly throughout the chassis, further allowing the decorative use of full windowed side panels. The vents themselves have the same mounting flexibility as the Infinite Vents system and have inspiration both from there and the Compact Splash project.
The low volume necessitates using an unconventional power supply - The HD-Plex 300 Watt AC/DC. This, paired with their 400 Watt Hi-FI DC-ATX, will enable even high-end configurations. I made sure to allow room for 2 of the 300 Watt Converters, mounted on opposing sides of the ITX Tray, so that bifurcated builds would have enough overhead when using a merger unit.
Project: Radian supports reference length cards, but currently only when using a single 300 Watt AC/DC Converter on the motherboard side. Otherwise cards that are less than 218mm long are supported in the current iteration. I have a workaround pending, essentially mounting them perpendicularly and at the same time giving them more airflow exposure! The mounting points probably won't have to change for this, enabling greater flexibility for the end user.
The current design revolves around using mod cubes for construction and mounting the Hi-FI DC-ATX unit, with the ITX Tray being 5mm thick acrylic and the other panels being 3mm thick. Of course, this is subject to change! Going to imperial units would give me a TON of options in terms of materials - using aluminum would allow for a much stronger chassis with fewer screws.
Now, as for the name... The whole idea was a large radiator capacity! On both the top and the bottom it can fit a 35.5mm thick radiator and a 25mm fan. Due to the modding cubes it's generally expected that the user will mount the fan against the panel itself, giving enough clearance for everything. With this system you can reasonably expect to mount dual 240mm radiators in this chassis.
Oh, and the overall dimensions are 310mm*283mm*130mm. So that's a total volume of about 11.4 Liters. Not bad.
Now to figure out placement for the power button and IO...
A note on pumps and reservoirs --
At this point in time, dimensions being as they are, I have 59.5mm of height clearance above the ITX Tray. This means I can definitely fit an XSPC ION reservoir(/pump combo), and potentially a low profile pump of some sort. Let me know if you guys find one with dimensions listed. AIO solutions are also a definite option, especially the expandable ones. That said, I do want to see about adjusting things to fit a normal tube reservoir.
