IDK if that is really reasonable, since the air gap between the feet underneath the chassis does not contain any hardware. @Aux set up the rule with the volume calculation, so lets see what they have to say about it.
Looks like it is bounding box, as your volume is adjusted to 6.94L in the above post...
@Aux , might we get a ruling on decimal places & any rules for rounding up/down...?
The dimensions of the case, if you look at a number of reviews, take note of such extrusions.
The dimensions in the advertising also typically note with and without protrusions.
For a number of these cases, if there were no airflow through the base of the case, the system would overheat and so the feet make a difference.
(see above for ventilation to case from underneath)
The case volume has a significant impact on the performance figure. Currently I round up to two decimal places.
At the end of the day, its up to us to decide if we want to do it one way or another. Im easy on these points.
