Discussion PPL - Performance Per Liter - Round 3 - Compute Edition...?!?
fabio
1,885
4,325
Sorry, I was thinking was related to mine because on the same line!
My mistake!!
thelaughingman
1,413
1,566
Updating my score - breaking the 24k mark
(6588 x 7267) / (7.28^1.5) / 100 = 24,373
  • Extra 100 pts from Cinebench thanks to new cooler
  • Extra 30-ish pts from Timespy thanks to cooler ambient
theGryphon
299
237
More performance, less liters.
Not in trying to clutter the thread with mouthing off though, so will update this post with my build later. Can't compete with @AURMEND, but still want to represent for the S4M crowd.
So you assume I feel bad that someone has a higher PPL system than mine? That's plain offensive. How presumptuous of you.
AURMEND
Destroyer of PCs
A&M Solutions and Design LLC
Jul 30, 2018
249
222
Stop using big words.
Plus I didn't make a build thread so it's harder to tell that I wasn't using a brick. The build isn't done, will be adding 3 40mm fans to this. I'm only using a 3950x because I basically got it for $300
Boil
1,253
1,094
[jedimindtrick]
You... You should trade that 300 doll hair 3950X for my 500 doll hair (ordered on release date) 3900X...
[/jedimindtrick]
CubanLegend
Steely-Eyed NVFlash Man
Dec 23, 2016
834
1,011
smallformfactor.net
@AURMEND brought me here lol. Note my build is from 2017 (using an S4M Classic) and is still running identical, just newer CPU cooler/fan. @Josh | NFC represent!
((2452*7863)/(4.9^1.5))/100 = 17775.205137361085
Note i have the 2D bezel so there's less volume that a stock S4M-C (due to no wrap-around bezel). Brick volume is included.
Case is 4.2L, brick is .7L hence 4.9L total
Benchmarks:
NEW CPU OC Result, 4.7GHz @ 1.28v :
OC'ed GPU (ZOTAC 1080 Mini Result is +200 core /+600 mem) 7863 Timespy:
I could OC the CPU (and i did, just for this) but i dont run it OC'ed, not that it made much difference, lol. :)
Reactions: deprecatedcoder
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
[jedimindtrick]
[/jedimindtrick]
alrteady have a 3900x that clocks better with lower voltages
Reactions: Boil
