PPL - Performance Per Liter, Round 2!
VegetableStu
1,949
2,619
quick question: why /100 at the end? (and why only two of them are divided by 100?) o_o
EDIT: nevermind, opened an excel file to check, they're all divided by 100. my bad ,_,
Kilrah
128
112
((2047*6479)/(4.786^1.5))/100 = 12667
Reactions: Soul_Est
Aux
179
156
no problems,
it seems to have started as the full fat number, @Majestic seems to have proposed div by 1000, but then @confusis does a div by 100 and it seems to have stayed that way from there.
And I just forgot to update the graphic to show all div by 100
Reactions: VegetableStu
VegetableStu
1,949
2,619
i think aux has a spreadsheet on their side? o_o it'll be most likely that they have the correct calculation on the board
if your case shrunk you should resubmit again (scale that ladder boyo)
GermanDrifter97
49
47
It would be interesting to see the case name in the posts too . ..
My case and rfarmer's 'old' case (for his 5204 score) is called the "CCD MI-6" (Case-by-Case Design co. MI-6, designed by Hardforum-member Firewolfy) if you want to add the name.
Aux
179
156
@Aux @VegetableStu Wait, did I do my calc wrong?
no, I recalculated all the data from the submissions. But if anyone sees an error, please let me know
I have an amd 3700x and rtx 2060 in and even smaller case now. I should probably rerun the numbers.
yep, submit a new result . .. lets see it. .
yep
I will add it later
Nemeses
32
Hi everyone,
I recently completed a very tricky ITX build using the Ryzen 3950x and two 2080Tis in SLI.
You can read more about here: https://smallformfactor.net/forum/t...sm580-dual-2080ti-sli-3950x-custom-loop.12254
Someone recommended I calculate my score per the rules of this thread, so here we go!
Main case
Width 6.10in
Height 12.7in
Depth 14.05in
= 1135 cubic inches
= 17.8 liters
Pump (measured as a cube outline)
Height 5in
Depth 3in
Width 6.125in
= 92 cubic inches
= 1.5 liters
Combined volume = 19.3 liters
Now for the scores, I have done a little tweaking using AMD's Ryzen Master and EVGA's X1 Precision, but haven't touched the BIOS besides setting the memory to its max clock of 3600mhz.
Cinebench R15 CPU: 4,068
3DMark TimeSpy Graphics: 24,832 (https://www.3dmark.com/3dm/43524714)
Final score:
((4068 * 24832)/(19.3^1.5))/100 = 11,913
Screenshots:
Vlad502
258
211
Code:
ZMan post#42              R7 2700 1848     GTX1080 7812           unknown 3.78 PPL ((1848*7812)/(3.78^1.5))/100= 19644
Gautam post#10            7960X 3994       GTX1080Ti 9630         unknown 7.9 PPL ((3994*9630)/(7.9^1.5))/100= 17322
GermanDrifter97 post#53   R9 3950X 3776    GTX1080 7505           MI-6 6.7 PPL ((3776*7505)/(6.7^1.5))/100= 16341
VELKASE Michael post#14   R7 1700 1660     GTX1080 7511           Velka3 4.0 PPL ((1660*7511)/(4.0^1.5))/100= 15585
neyurt post#29#47         9900K 1963       GTX1080Ti 10200        custom 5.5 PPL ((1963*10200)/(5.5^1.5))/100= 15523
AURMEND post#39           9700K 1608       GTX1080Ti 10271        custom 5.37 PPL ((1608*10271)/(5.37^1.5))/100= 13272
Kilrah post#62            9900K 2047       GTX1070 6479           custom 4.8 PPL ((2047*6479)/(4.8^1.5))/100= 12611
caniplaymayo post#37      R7 1700X 1600    GTX1660Ti 6034         unknown 4.0 PPL ((1600*6034)/(4^1.5))/100= 12068
Nemeses post#69           R9 3950X 4068    RTX2080Ti SLI 24832    SM580 17.8+1.5 PPL ((4068*24832)/(19.3^1.5))/100= 11914
petricor post#8           8700K 1605       GTX1080 7903           S4M(modded) 5.0 PPL ((1605*7903)/(5.0^1.5))/100= 11345
AURMEND post#21           9700K 1451       GTX1080Ti 9317         custom 5.37 PPL ((1451*9317)/(5.37^1.5))/100= 10864
GermanDrifter97 post#11   R7 1700 1562     GTX1080 7545           MI-6 6.7 PPL ((1562*7545)/(6.7^1.5))/100= 6795
TroyMSLprod post#7        8700K 1596       GTX1070 5960           S4M 5.0+0.86 PPL ((1596*5960)/(5.86^1.5))/100= 6706
Nanook post#20            9900K 1934       RTX2080 11032          GhostS1+2*M 8.2+2.6 PPL ((1934*11032)/(10.8^1.5))/100= 6011
rfarmer post#4            8700K 1405       GTX1070 6423           MI-6 6.7 PPL ((1405*6423)/(6.7^1.5))/100= 5204
rfarmer post#48           R5 3600X 1660    GTX1080 7759           Nouvolo Steck 8.7 PPL ((1660*7759)/(8.7^1.5))/100= 5019
Majestic post#5           R7 1700 1407     Vega56 6287            LZ7 7.07 PPL ((1407*6287)/(7.07^1.5))/100= 4706
K888D post#9              8700K 1476       GTX1080Ti 10086        LZ7 XTD 10.4 PPL ((1476*10086)/(10.4^1.5))/100= 4439
rfarmer post#43           8700K 1603       RTX2070 9707           GhostS1+L 8.2+2.8 PPL ((1603*9707)/(11^1.5))/100= 4265
Wyd4 post#17              8700K 1564       GTX1080Ti 10554        NcaseM1 12.6  PPL ((1564*10554)/(12.6^1.5))/100= 3691
Duality92 post#2          7300U 362        HD620 391              LivaZ 0.63 PPL ((362*391)/(0.63^1.5))/100= 2831
Curiosity post#45         3570K 529        GTX1060 4227           K39v2 4.6 PPL ((529*4227)/(4.6^1.5))/100= 2266
Duality92 post#3          8600K 959        GTX1070 5559           unknown 10.4 PPL ((959*5559)/(10.4^1.5))/100= 1590
Aux post#41               8086K 1283       RTX2080Ti 14537        LianLi A51 44.2 PPL ((1283*14537)/(44.2^1.5))/100= 635
confusis post#6           G4560 299        GTX750Ti 1137          unknown 5.3 PPL ((299*1137)/(5.3^1.5))/100= 279
AURMEND
Destroyer of PCs
A&M Solutions and Design LLC
Jul 30, 2018
249
222
((1584*10415)/(5^1.5))/100=
14755.6873637
5.0Ghz 9700k NH-L9I W/ 120MM NOCTA
3600 c17 vlp ram 32GB
zotac 1080ti mini W/ 92MM NOCTUA
CPU score will raise once i get a Black Ridge 120mm setup or NH-l9i w/ 120x25 f12 3000rpm Noctua
Aux
179
156
Not entering officially, just wanted to see where I would be on the list for fun.
This is in a DanCase A4 under a 645LT.
(3173 x 14460)/(7.2^1.5)/100 = 23748.68
R9-3900X @4.3GHz all cores
4113Mhz @ CL16
2080TI (1,995 MHz/1,975 MHz)
If you entered officially, you would be right at the top. . . . so we just need some pictures now. .. .
