I'm doing my first NCASE M1 build using the ASRock B550ax ITX motherboard (arriving this coming Monday). One of the unfortunate design decisions by ASRock was to implement right angle SATA ports on the very edge of the board. From what I can tell having installed the power supply in the normal spot is there will be no clearance between the SATA ports and the side of the power supply. I know you can just move the power supply bracket so it's supported from the front (see picture), but more ideal would be some method to mount the power supply in the normal orientation, but spaced away from the side of the case by about 1 inch so SATA ports would be clear. This seems like a custom job as just getting long screws and spacers would be a mechanical disaster. Anyone have other ideas? I was hoping to use the disk drive area which gets eliminated if you mount the PS as pictured.
