Hello,
I will try to assemble a pretty powerful and probably hard-to-cool machine with an NFC S4 Mini. The challenge is not really the PCI-E card because that will be 'only' a NIC. It is the CPU itself. I would like to try some CPUs from 65W to 135W.
Materials as of now:
* mobo: Asrock Rack EPC612D4I because it has 4 channels
* PSU: HDPlex 250W, the 'classic' one used in many S4 Mini builds. Have a HP 240W brick for this.
* CPU: E5-2650L v4 (engineering sample, for cheap, from ebay)
* CPU cooler: Dynatron t318 heatsink with a rosewill 120x15 slim fan
* memory: 4x8G Kingston KVR21SE15D8/8HA from the supported list
* NIC: 2x Intel XL710-QDA2
The case is a 'Just Orange' version with Blaze plastidip shots. Gives it a unique texture and a hint of a nuclear reactor orange color.
This will not be a lightning-fast project because the main goal is to have the fastest available virtual router for us. It means changing CPU, cooling and probably the NIC, too, so all the components will be tested and tuned on a bench and will be installed into the case only when the config is close to the final.
As the S4 Mini offers plenty of space for PCI-E card maybe I will try to use 2 cards (x8) through bifurcation (to get closer to the theoretical maximum of 64Gbps) if the NIC has other bottlenecks or the 4x10G mode will be preferred.
No pictures yet
No pictures yet
