Hello friends of the SFF.
I got a plan to build a System in the Velka 3 Case with the Flex ATX PSU SilverStone SST FX350-G, which only has a 6-pin PCIe power cable for a GPU. Now I wanted to put a Ryzen 5 1600 inside (because it's quite cheap at MicroCenter) and this GTX 1660, I've already checked all the necessary Dimensions and the only thing left is to be able to power it. It needs 8-pin PCIe power and as I have already said above the PSU only has a single 6-pin PCIe power cable. I do have a 6-pin to 8-pin adapter but I don't really want to use it for fear of underpowering the GPU (even though the GTX 1660 should never draw anything near the maximum output from the PCIe slot and 6-pin PCIe) I do notice that the PSU has 2 Molex connectors, though. I happen to have a dual molex to 6-pin adapter from an older GPU. Can I make a "Zombie Connection" with 2x Molex to 6-pin PCIe and then 2x 6-pin PCIe to 8-pin PCIe?
Thanks in advance!
Thanks in advance!
