NCASE M1 V6 info
fatpolomanjr
30
37
@fatpolomanjr do you have the bottom filter in-place? How are you able to use both the filter and the Noctua anti-vibration mounts together?
I didn't even think of this potential issue, since I figured having the fans as exhaust negates the need for the dust filter. Thankfully Warside already replied it does fit.
Reactions: xSDMx
xSDMx
31
No. The standard ones that come with the F12 fans (SAV2).
Did you cut off the bottom of the SAV2 mounts to fit? Any chance you would have time to share a quick photo for reference? Thanks. I need to get new fan grommets anyway, so I'm debating which SAV replacements I should order that would best suit the NCase.
turboleak
108
94
What RAM and cooling options are you thinking of pairing with your crosshair impact. I pre ordered the impact as well.
Just got notice that the impact is on it's way!
I am going to pair it with a delided, bare core on cpu block 3950x ( as soon as I can grab one ), with g.skill F4-4000C19D-32GTZR ( 2x16GB 4000MHZ CL19 ).
Regarding cooling I will try to fit the Enermax LiqTech II 240mm ( it has the thickest radiator I could find at 39mm and supposedly capable of removing up to 500w of heat ). Its also on its way right now.
For storage, 2x corsair MP510 2TB
For GFX I will keep my 1080 until the new generation of cards is released next year.
Reactions: Rolling9Deep
Warside
44
27
I didn't cut anything :)
I've added 2 more photos to my build on pcpartpicker: https://pcpartpicker.com/b/Mfw6Mp .
EDIT: Ooops. You're right, the default grommets are labeled NA-SAV1!
Reactions: xSDMx
Nazirite
28
Aaaaand now bad news... had to reschedule my delivery because I was out of the country. Redelivery date came and past and looks like USPS has lost the package. Tracking says “moving within USPS network“ for 3 days and no update, doesn’t make sense since it should be re-delivered by local post office.
turboleak
108
94
Wow going with a $450 ramkit for 32gb?
It's the fastest ram available ( there are some corsair 32gb kits at 4100 but they cheat by upping the voltage to 1.4. The g.skill does 4000 at 1.35 ).
Reason for the 32GB kit is that I run a linux vm on my pc and need quite a lot of memory. Reason for 4000mhz is that I want to try to run the memory controller of the cpu at 2000mhz and the last thing I want is not being able to do it because of the memory.
The memory costs around 300USD in Europe.
lcxlim
Finally have my M1, was disassembling my old build and it looks like I need a new cooler.
Can anyone or Necrere help me confirm that the C14S will fit? Concerned that the socket is too high and the RAM too tall, but there was one user that managed to make the C14S fit with 47mm tall RAM.
Motherboard: Asrock Fatality B350
RAM: Ripjaw (42mm tall)
fatpolomanjr
30
37
I can confirm the ram height when I get home today, but as far as I know the only confirmed motherboards with sockets that are too tall are a few of the X570 boards.
lcxlim
Would definitely appreciate it! For reference, this is the post I was wondering about ram clearance. It seems I’d probably have to buy a different fan, the A12x25?
Dries
24
Ram clearence is 40mm with the 25mm fan
lcxlim
Right, but if you see the post that I linked to (should be proper now, mobile formatting is a hassle), that person was able to fit the C14S in low profile mode with Trident Royal sticks, which are 47mm in height.
fatpolomanjr
30
37
I can't tell you much more than the specifications, since I've since shoved everything back into my Dan case for now. Measuring the C14S alone I can only tell you that 42mm is the measurement from fan to cpu. Which is already clear from the specs.
Dries
24
He using his power supply in standard position, so he had to replace his c14s standard 140mm 25mm thick fan with another, he must be using a 15mm fan.
Fire
28
i just tried to mount 2 2,5" SSDs in the front, behind the front cover ... it seems that they are a little to high? am i right or should it work? do i need the optical drive bay when i want to mount 2 2,5" SSD in the front behind the cover? (i don't mean inside)
