I'm an Italian living in Canada, I bought the Ncase because I can bring it with me when I'll move back to Italy!I can also speak for Alex (same destination country, same dispatch batch). There're no foreign information while we track the package w/ http://postserv.post.gov.tw/pstmail/main_mail.html and "Poste Italiane" still didn't register the shipment.
I suppose it's due to Poste Italiane (they also are responsible for customs in Italy) that still have not processed that batch coming from Taiwan.
Italian customs are so shitty that a lot of CN/HK couriers prefer to import goods via Germany, UK or France instead of Italy. It's a shame.
@Necere: I'm curious. How many Italian folks did buy the M1?
Marvelous. Thank you for the info and your transparency. Great customer service!So, update on the front I/O plate situation - I've just spoken with Lian Li, and there was actually a reason they didn't laser cut the plates: the laser cutting machine will produce small scratches on the material. Normally they clean this up with the brushed finishing, but these parts are too small to be run through those machines. The NCT produces scratches as well, but in that case they protect the surface with a plastic sheet while it's cutting. That won't work for laser cutting though, since the laser will melt the sheet. So these parts effectively can't be cut using the laser.
There is hope however: they're working on a solution using custom tooling which should result in cleaner edges. Assuming it works out, these will be in the next production run. I'd also like to offer them to people who already have the V6 and want replacement plates, though that'll take some time since they'll be manufactured alongside the next M1 production run (likely December-January).
Hello everybody! I've got 2 questions for you all, so if anyone could take some time to answer that would be much appreciated.
- Question 1:
I'm eager to get my hands on the V6. Ordered the silver version the day the preorders went live, and since then I've received no updates on the shipping.
I am not really active here, but I've read both here and in /r/sffpc that there was a shipping problem regarding the silver M1.
Is there any updates on that? Should I be worried?
- Question 2:
I was thinking of buying the Aorus X570 board and the C14S CPU cooler from Noctua, but the motherboard socket seems to be placed quite high so the cooler interferes with the top panel. Some users have asked Noctua for a mount that allows a 90º rotation on the cooler, however this is not recommended by Noctua themselves, as seen in the C14S' instructions manual:
I understand why such orientation is not recommended, as the high temperature of the fluid could cause it to "stay" on the heatpipes so the radiator would not dissipate as much heat... But I'm unsure of the practical difference (as in ΔºC or noise levels).
So, as silence and performance are my priorities, my current alternatives are as follow:
What are your thoughts on my current situation? Do any of you have any way of testing the C14S orientation?
- Rotate the C14S
- Buy the ASRock motherboard (but I don't think its fan could be removed, something that I think it's possible with the Aorus board)
- Wait for B550...
(Quoting @Necere because as the designer you might have some insight on this... And this way I can also praise your improvements on the V6 hehehe)
Best regards to you all!
1. Track the shipment using http://postserv.post.gov.tw/pstmail/main_mail.html
2. I have the Aorus X570 + Noctua C14 (yes, the old model). I can check if it fits as soon as I receive the case.
2. I've read the C14 fits fine, so you should be good to go! However, not only I find the C14S more interesting (due to the thermal results seen here) but the original C14 is nowhere to be found where I live, so that is not an option for me.
Hi, on regards on the aorus MB and the c14s. Someone tested that on Reddit, link in another topic on the forum. Some topics down. It seems only one way to fit as you mentioned not recommended by noctua.Hello everybody! I've got 2 questions for you all, so if anyone could take some time to answer that would be much appreciated.
- Question 1:
- Question 2:
- Rotate the C14S
- Wait for B550...
ASRock board has it's socket a bit more down. But in my opinion i doubt if it will be enough, it will be a very close call. Didn't find any pics of some who did the same combo.
I Will use a b450 Asus board, cant wait any longer... B550 are announced but if they come as fast as x570 boards, likely next year...
Gonna do a super amateur level stream of my trying to set mine up. Was gonna be for a friend that wanted to watch but thought I might as well open it up to you guys. Ttv/haaas. Maybe in like 15 min
Anyone using a fan hub or just using fan splitters? I'm using asus b450 and only have 1 additional fan header on top of cpu one. Will be using 2 noctuas underneath gpu but thinking of an additional exhaust as well on the 92mm rear fan mount.
Do you talk about an Asus B450-i Strix? You got 3 fan headers. Cpu, Aio and sys-fan. I think you can use the aio header for fans no problem.Anyone using a fan hub or just using fan splitters? I'm using asus b450 and only have 1 additional fan header on top of cpu one. Will be using 2 noctuas underneath gpu but thinking of an additional exhaust as well on the 92mm rear fan mount.
I'm using an aio but @NeverBackDown was spot on about getting y splitter with my noctua's. Although didn't get them with my 12x15 ones previously so assumed I wouldn't get with the 12x25. ?Do you talk about an Asus B450-i Strix? You got 3 fan headers. Cpu, Aio and sys-fan. I think you can use the aio header for fans no problem.
