Is there anyone else here who’s waiting for the itx mobo from asus?
Available in the Netherlands for 320 euro's while the Aorus x570 itx is 250...Is there anyone else here who’s waiting for the itx mobo from asus? Any idea when they should be available for purchase? Been checking on all the possible websites across Europe still nothing.
Got all the components ready, getting really impatient now
Hi, I'm new to the SFF scene and wanted to just double check that Im not screwing up here. my plan is to buy the Gigabyte 2070 super Gaming OC, with the measurements of L=286.5 W=114.5 H=50.2 mm. Thats going to fit, but i'm going to have to remove the front IO right?
And as a second question there, 15MM Noctua nf-f12s are going to fit underneath?
Cant wait for the M1 to arrive, it has to be the most beautiful PC case I'v ever seen!
by the way Komplett.no has the Strix board as incoming the 27.09. so I would assume that would be the date for larger parts of Europe.
Thank you!Yes, based on the v6 renders that Necere has released, you are correct. A graphics card that thick and that long will require removal of the Front I/O and will only allow thin fans like the 15 mm Noctuas to fit underneath.
The board you mentioned has both m.2 slots in the frontHello, I wanted to put a m.2 m key to PCIex4 adaptor on the m.2 slot something like this (Amazon product) on the back of the asus x570 i gaming and then run a riser cable to an HBA to get more drives using the unused m.2 slot. My question is do we have much space behind the motherboard in between it and the case wall? Also would the HBA be able to occupy a slot on the case along with the evga rtx 2060 super xc gaming gpu? I also wanted to put some Noctuas A12x25 down there so might get too cramped?
Looks like the shipping date is the 27th of September at the latest currently according to the website.
"Orders placed by September 22nd are shipped by September 27th "
