NCASE M1 V6 info
Zutko
24
I haven't heard anything. I assume things are on schedule.
Only full panel kits, ODD top panels, and front I/O kits will be available initially. I think that won't be until after the M1s start shipping.
When you say full panels kit, we are talking about side panels, top and front? Cos I need sidepanels only, but I'll go for top panel as well if that is the case :)
Zutko
24
And will front IO be compatible with V5. And while we are on the subject: do you have a price for front IO kit and panel kit?
Necere
NCASE
3,300
Panel kit = all four exterior panels (front/top/left/right).
Yes, the front I/O kit is backward compatible with all versions. No prices yet.
JaPeMo
82
41
@Necere or somebody do you know if Alphacool Eisbaer 240 or LT240 or can be install in ncase?
Wich is de max distance for RAD (X mm) + FANS (25mm) for AIOS, 24 or 30mm?
I see this in first page:
  • Radiators less than 35mm thick are recommended
Perfect!!
Thanks!!!
Terse
I think the LT240 will fit, I dont think the regular 240 will fit.
From alphacool's website for the individual eisbaer pump/res combo:
pump/res height 68 mm +
30 mm rad thickness +
25 mm fan thickness
123 mm of the max 130 mm cpu block height. If the 68 mm is without fittings, I dont think this will fit. If the 68mm is with fittings installed, then maybe some right angle fittings would make it fit.
You could also leave off the fan for the half of the radiator that is directly above the CPU, but you would lose a lot of performance.
Reactions: JaPeMo
HottestVapes
135
131
Perfect!!
Thanks!!!
The LT240 definitely fits. I had to run the tubing from the rad on the CPU side and finagle the tubing around, but it fit well and performed well for me. Still using the radiator off it too now in a custom loop.
bluestofblue
110
73
@Necere do you have any pictures of this; "New adjustable GPU support bracket (adjustable for 2-2.5 slot cards) "? Also, do you know if this bracket will work with a 2.75" card? I am trying to see if a 2070 Super XC Ultra will be able to take advantage of the bracket.
Necere
NCASE
3,300
It's visible in one of the images in the first post. It has 10mm of adjustability, which is about half a slot, and supports cards between 40-50mm thick (2-2.5 slots). 2.75 slot cards won't leave enough room for the bracket underneath.
JaPeMo
82
41
25 mm fan thickness
Yes yes, I know.. I asked becouse I would like install a 30mm rad. 24mm Is very low profile. I don't know if in comparison have a several diferences un temps...
@Necere what is the maximun dimensions for a rad? X x Y x 35mm?
Maybe I build a custom loop with a some of this rads (in order of preferences):
1. Alphacool NexXxoS ST30 Full Copper X-Flow 240mm radiator (LxWxH: 293 x 124 x 30mm)
2. Alphacool NexXxoS ST30 Full Copper 240mm radiator V.2 (LxWxH: 278 x 124 x 30 mm)
3. Alphacool NexXxoS ST30 Full Copper 240mm radiator (LxWxH: 275 x 124 x 30 mm )
@Necere what is the maximun dimensions for a rad? X x Y x 35mm? And, If I pre-ordered Jul 31st my V6, when do you think they would send it?
Thanks & Regards
Necere
NCASE
3,300
I would say about 295x145mm. Internally there's 307mm from the inside rear to inside front of the chassis, but you have to clear the flanges when installing. It's 289mm between the flanges, so anything over that you have to angle in. Also keep in mind that a fan on the rear and/or drive on the inside-front will eat into the available space by their respective thicknesses.
SFFLab gave you a shipping date when you ordered. I believe it was September 20th.
Reactions: JaPeMo
JaPeMo
82
41
I think that V2 is the best option
Yes I see know in my email, sorry & thanks
Nazirite
28
Whats everyone planning to put in their NCASE?
So far I have Ryzen 3600x, 2070 Super, Ballistix Sport LT 32gb, 4 Noctua Redux 120mm fans (might have went a little fan happy, might not use them all but too late to return), Scythe Big Shuriken 3, Corsair SF750, Crucial P1 M.2.
Just waiting on a good x570 itx motherboard and pslate custom cables. Also need to figure out what SSD I want for front panel and a good 1440p monitor.
I might have went a tad overboard for my first PC build but I’m excited to actually start assembling it once I get my NCASE.
Reactions: roozter
JaPeMo
82
41
HARDWARE:
Asus ROG Strix X470-I Gaming
AMD Ryzen 7 2700X
G-Skill Trident Z 16GB DDR4-3200 CL14
KFA2 GeForce® RTX 2080 OC
M.2 Samsung 950 PRO 500GB
SSD Samsung 840 EVO 750GB
HDD WD Green 3TB Ext.
Corsair SF600
Asus PQ348G
Logitech G710+
Logitech G502 Hero
W10 Pro
COOLING (to decide...)
AIR: Noctua NH-C14 + Corsair Reposition fans H115i (like a ML140PRO specs with RGB)
LIQUID: Alphacool Eisbaer LT Black + FrozenQ M1 reservoir + Aquacomputer QUADRO + RGBpx Splitty4 + 4 Corsair Reposition H100i (like a ML120PRO specs with RGB)
I use RGB only to see temp of my computer. (BLUE - Cold <-> RED - Hot)
Reactions: Titchiboi
Moondragon
Hardware:
ASUS X570-I (if it ever becomes available)
AMD Ryzen 3700X
240mm AIO Liquid Cooling
32 GB 3600MHz RAM
Samsung 970 EVO Plus 1TB
SATA SSD 2TB
possibly additional SSDs
AMD RX 5700 XT (have not decided which one, yet; depends on macOS compatibility)
2 Noctua NF-A12x25/15 (depending on cooling needs and available space)
Corsair SF750
Software/OS:
macOS Catalina, Linux and Windows
This System is going to replace my 2013 27" iMac.
XFC3
35
24
I never got an estimated shipping date. I put my order in July 22 and it got canceled because of the free shipping. I then put another order that same day and chose the $65.00 shipping but never got an estimated ship date, I ever checked the emails to see and nada.
AlexH
37
I’m still unsure. So far bought only
Corsair DDR4 32GB c16
Samsung 970 evo m.2 1TB
Corsair H100i v2
Corsair sf600 platinum
As for cpu I was thinking about the ryzen 3000. And gpu wise no idea whatsoever for now
