PSA: If your order looks like it's stuck on "Origin Post is Preparing Shipment," don't worry. This means your package is in transit. The next tracking update will be when it lands in the destination country.
I guess so? USPS delivered mine to my door.What does this mean:
Your item arrived at the MIAMI, FL post office at 12:58 pm on December 28, 2019 and is ready for pickup.
They aren't going to deliver to me? I have to pick up from the post office?
My ncase came! Only 8 days, of which 2 were federal holidays, from Taiwan to my door in DC.
From sfflab with $30 (cheapest) shipping.Hi ! just being curious but did you buy it from sfflab? did you choose the normal or the quick delivery method? I'm being impatient after 4 months of part picking ?
Why not just write your questions and maybe someone can answer them directly? That way someone else that might have the same questions as you, get the answer directly from here. After all, this is a forum for everyone
And to your question, is there a specific 2080 Super you have in mind? In other words, ASUS, MSI, Gigabyte and an reference or AIB?...
how hot the 9900ks wil get in this case and with kind of cooler?
the 2080 is a founders edition.
is this case recommended with this setup?
i9 9900 ks
air cooler ?
asrock z390 itx
32 gb ram gskillz
rtx 2080 founders edition
sf750 psu
i9 9900 ks
air cooler ?
asrock z390 itx
32 gb ram gskillz
sf750 psu
when the stock will available?FAQ
Q: When/where can I order the M1 V6?
A: M1 V6.1 is available to order directly from our site, ncases.com. We are out of stock currently, with the next restock scheduled for January 1st.
Please note: after the January 1st batch sells out, we won't have stock again until late February.
Q: What other parts will be available?
A: TBD
Q: Will there be a window option?
A: TBD
Q: Will x fit?
A: See the specs towards the end of this post. Also see the GPU compatibility list.
Q: Which parts are backward compatible?
A: The following parts from V6 are backward compatible with older versions:
- Exterior panels
- Front I/O bracket w/ports
- Side fan bracket
- 3.5"/2.5" and ODD drive brackets
- Motherboard tray
M1 V6 User Manual - see end of this post
M1 V6 changelog
V6.1
Chassis
-Adjusted front SFX mount position
-Adjusted 2.5" mounting holes
-Adjusted 2.5" drive SATA connector cutouts
-Added threaded standoffs to fan bracket mounting holes
Front I/O
-New punch tooling for smoother edges
SFX bracket
-Added/modified flanges to mitigate possible PSU movement
ODD bracket
-Adjusted 2.5" drive mount screw holes for improved stacking bracket support
-Added chassis mounted 2.5" drive screw access holes
-Adjusted aux chassis 2.5" drive screw access holes
Parts box
-Removed 120mm fan filters
-Fan grille count changed to 2
-Adjusted screw counts
Power cable
-Changed to right angle
V6
Front I/O
-Added USB Type C port (requires motherboard 20 pin Type E header, see list)
-Changed headphone and mic ports to single combo jack
-All ports use new molds
-Redesigned I/O bracket with swappable no-I/O faceplate (ports can be removed for cleaner look/slightly better 2.2+ slot GPU compatibility)
Chassis
-Redesigned ventilation holes on bottom and rear to improve airflow
-Added longer fan mounting slots on the bottom
-Bottom vents moved to separate steel floor plate attached to underside of chassis
-Added bottom magnetic dust filter
-Threaded inserts on PCI bracket
-Added M4 screw holes for window mounting to chassis
-Front-right chassis flange reduced, SFX PSU can now be installed from the right side
-Reduced rear-left chassis flange to facilitate GPU installation
-Enlarged chassis front GPU passthrough to facilitate GPU installation and provide more room for oversized GPUs
-Removed four panel mounting clips from side flanges to reduce incidence of oversized GPU conflicts
-Changed front 2.5" drive mounting to use screws instead of rubber grommets to save space/reduce complexity
-Integrated fan bracket mount into chassis flanges
-Added inside-front mounting for SFX PSU
-Added Kensington slot to rear
Fan bracket
-Added more and longer 120mm fan mounting slots for greater range of mounting
Motherboard tray
-Changed to removable standoffs
ODD bracket
-Redesigned to single piece, now supports 9.5mm and 12.7mm ODD drives
HDD cage
-Redesigned to two pieces, now supports 2x 3.5" drives *or* 3x 2.5" drives; now allows mounting to inside front 2.5" mount (3x 2.5" configuration only)
Top panel
-Changed to 2mm thick
Side panels
-Extended ventilated area adjacent to GPU
Other
-New 15mm tall molded rubber feet
-New adjustable GPU support bracket (adjustable for 2-2.5 slot cards)
Renders
Full Specs
M1 V6 User Manual
Volume
- 12.7L
External Dimensions
- Including feet & protrusions: 338 x 160.6 x 255.5mm
- Excluding feet & protrusions: 328 x 160.6 x 241.7mm
Materials
- Exterior panels: brushed anodized aluminum, 1.5mm front and sides, 2mm top panel
- Interior frame: 1.5mm matte black painted aluminum
- Interior fan bracket and vented undercarriage: 1.2mm black steel
Front I/O
- Power button with dual-color LED backlight (power on/HDD access)
- Two USB Type A ports (to 19 pin USB header)
- One USB Type C port (to 20 pin/Type E header)
- One 3.5mm headphone/mic combo jack (to HD Audio header)
- Blank no-I/O face plate included
Motherboard Support
- Mini-ITX, Mini-DTX
CPU Cooler Support
- Maximum height: 130mm with side fan bracket installed, 135mm without
- CPU Heatsinks must not extend past the top edge of the motherboard by more than 10mm.
- CPU Heatsinks that extend beyond the front edge of the motherboard may interfere with the 3.5" HDD cage and/or power supply (in the default right-side mounting location).
Graphics Card Support
- Cards up to 280mm long (up to 290mm with front I/O ports removed):
- Height: up to 140mm at mid-card, 130mm at rear corner
- Thickness: up to 3 slots (60mm)
- Cards over 280mm long:
- Height: up to 140mm at mid-card, 130mm at rear corner, 125mm at front corner
- Thickness: up to 2.2 slots (45mm)
- Note on height limits: please allow 15-20mm for PCIe power connectors
- Also see GPU compatibility list
Drive Support
- Optical Disc Drive (requires optional top panel with ODD slot)
- ODD bracket supports slim slot-loading optical drives in 9.5mm or 12.7mm sizes
- Alternatively, bracket may be used for a single 2.5" drive (up to 14mm thick)
- 2x 3.5" HDDs supported via removable brackets attached to the fan bracket (uses up one side 120mm fan location)
- Alternatively, brackets can support 3x 2.5" drives (up to 15.5mm thick)
- 1x 2.5" drive mount on inside-front of chassis (any thickness); also supports mounting of the HDD brackets in 3x 2.5" drive configuration in place of a single 2.5" drive
Fan Support
- Side (fan bracket): 2x 120mm
- Bottom: 2x 120mm
- Rear: 1x 92mm
Liquid Cooling Support
- 1x 240 radiator or up to 2x 120 radiators are supported on the side fan bracket
- Radiators less than 35mm thick are recommended
- 1x 240 or 2x 120 radiators precludes use of the HDD brackets attached to the fan bracket
Power Supply
- SFX, SFX-L
Other resources
- User builder gallery (M1 V5 and earlier)
- NCASE M1 Discord server
This is great! Do you know, by chance, if Noctua NF-A14 or NF-A15 would fit as well?
NF-A14 PWM chromax.black.swap
NF-A15 HS-PWM chromax.black.swap
I'm trying to assemble component for a future v6.1 build during holiday shopping season - before getting a case .
Thanks!
The plan was for 12pm PST/8pm GMT, but there may be a bit of a delay as I need to confirm the shipping schedule with w360 and it's currently 3am where he is.when the stock will available?
Here with us it is 21:00pm so what time i can order.The plan was for 12pm PST/8pm GMT, but there may be a bit of a delay as I need to confirm the shipping schedule with w360 and it's currently 3am where he is.
Some time over the next 12 hours. Read the website?Here with us it is 21:00pm so what time i can order.
As soon as w360 wakes up and tells me when we're shipping.Here with us it is 21:00pm so what time i can order.
Torn between silver or black!Waiting patiently! Hope I get one!
