As the title suggests, this is just a concept.
This has been a very enjoyable project of mine that I've been working on for some time now. Being 15 and having access to a student version of Autodesk inventor 2017, I decided to make what was originally some sketches into an actual design in inventor. I've planned this to be a mITX custom loop capable case with 2 280mm rads and a 140mm fan. Overall, I'm really happy how it turned out, but it could still use a lot of work. Although it looks like a regular case in the picture, if I had something for scale, it would be much easier to tell how small it is.
MOBO: Nothing special here, just a regular mITX board
GPU: just a vertically mounted GPU to show off the nice looking side of the gpu (also to align the holes in the water blocks on the GPU with those on the CPU)
Fans/Radiators: Im planning on using caselabs' radiator mounts and slim 30mm radiators to be able to fit everything. I've double checked on all clearance issues that might exist and have given an extra 5mm in all spots where fans+radiators need to be mounted.
PSU: I've desgined it so the PSU (supports ATX PSUs) is mounted on its side at the bottom of the case, with a vent for the fan on the back of the case.
Resovoir: Still not sure on this one... I might try to mount it next to the 140mm fan and remove the hole for cables below it.
Storage: Planning on using M.2 storage for the most part, but there is enough room next to the mobo tray to mount a 2.5in drive of some sorts (or a Hue+)
Case: The overall dimensions of the case are around 420mm x 320 mm x 160mm (I cant get exact dimensions since I made this in a trial of autodesk inventor 2017 before I knew I could get a copy of the 2015 version through my school and autodesk inventor isn't backwards compatible. These dimensions are just from memory, the pictures are through autodesk's software "autodesk view")
Feedback is welcome, and appreciated.
As I said, this is my first design, I have plenty more ideas and I really enjoy sketching and designing cases and I really would love to get a job in a field like this one day
Plans for the future with this design:
- Determine Reservoir Location
- Determine 3.5in and/or 2.5in drive locations
- Make it look nice
- Turn it into actually manufacturable parts instead of one concept part.
- Make it look nice
