Please replace also AU with EUOh yes I'm about to go full Oprah on everybody from AU and KR! (give me a couple of hours)
Replace "car" with "tracking number"
Oh man!! You have to post an unboxing video!! I really want to see what steel looks like!!AWHHH DANG MJOLNIR STEEL HAS BEEN SHIPPED TO CANADA!!! anybody else?
I'm Steel US and haven't gotten an email yetAWHHH DANG MJOLNIR STEEL HAS BEEN SHIPPED TO CANADA!!! anybody else?
Same here, would love to see the steel!Oh man!! You have to post an unboxing video!! I really want to see what steel looks like!!
I guessed just as much, probably to prevent spam. Although I felt that either the procedure could have been spelled out in the update, or accept that as a business you gotta make your contact address public.I used the form on their webpage. They said they got my email so it should work for you also.
However, they haven't replied in over a week but they also aren't going to deal with defects at this time.
@beerbuddha here is how I have my booster cell set up with the same noctua fan you have with the extension cable on:
You can see how I wrapped the cable in the pictures.
For anyone doing a custom loop, the bitspower tarasque 120 slim radiator is a PERFECT fit for Mjolnir:
I reccomend it, its the only 120mm radiator that seemed to match Mjolnir's lenght requirements (without modification of courselol).
I haven't receive any email. I even checked my Spam folder, none.AWHHH DANG MJOLNIR STEEL HAS BEEN SHIPPED TO CANADA!!! anybody else?
Alex my friend, can we get some more clarity on the vertical stand?
From what I remember reading it sounded like it would potentially replace the front plate/booster cell portion of the case? I think that's actually backwards of how you'd want to do it, if so. It would leave all the cables just a jumbled mess coming out of the top, and remove one potential venting/fan location.
Instead, I propose you make it a baseplate to replace the back of the core with. You could leave a small cutout to allow cables to passthrough discretely. This would also allow people to easily keep the core flat on the desk and remove the casing/shell alone if they wanted to. On top of it, you could then use the booster cell up-top as a exhaust fan, with the two side 120mm fans pulling air in, and using natural heat convection to help remove hot air from the case.
Again, I think if you wanted to go a bit further, you could make the accented piece frosted/diffused plastic or glass, and have ARGB lighting integrated with it as well. I'll come up with some drawings later to make it more easy to picture.
OOOHHHhhhhhh so the cables will be UNDER (base)....no you have my attentionI'm right there with you on that idea, that's actually what we had in mind!Perhaps this shows it more clearly, the idea is that the Dock replaces the back panel of the Core:
Dock (standalone)
Dock (mounted to the Core)
The cables are passed through the opening on the back
Dock (mounted to the Core) + Shell
We can potentially make it so that the internal lighting from the Godrays shines down through and on to the silver piece like @wolfatpno suggestedNot sure if the opening for the cables on the back is too large? However, we should be careful making too small as well considering that some GPUs (blower style) are dependent on good exhaust out the back.
That opening for cables looks to be perfectly sized, I'd say. Might I suggest moving the USB C connection to the opposite side of the cable opening, though? I imagine that would be the "front" as most people would configure a vertical Mjolnir. If you can make it so that the cut-out is opposite the side of the 2x 120mm intake fans as well, it could make for some interesting appearance.I'm right there with you on that idea, that's actually what we had in mind!Perhaps this shows it more clearly, the idea is that the Dock replaces the back panel of the Core:
Dock (standalone)
As a crazed saturday evening idea thought that shouldn't be taken so seriously, although what you say about blower GPU is really relevant and important. If you sliced the base like this, you can get 2x bases with the material of one, increase the airflow for blower GPUs, more directions the cables can escape, and from certain angles it may look like the mjolnir is floating.I'm right there with you on that idea, that's actually what we had in mind!Perhaps this shows it more clearly, the idea is that the Dock replaces the back panel of the Core:
