bruub
32
50
There is no both side mesh panel option?
And is riser cable included?
The FAQ has a mention about the "included riser cable" so I would hope that means included with the case.
Marvelm
232
106
You're right, that should mean it's included, good catch!
2,195
2,212
I get that this is meant to be an affordable case, but a mass-market case with a PCIe 3.0 riser cable in 2021 ... that's going to cause major issues. Zen 2, Zen 3 and Rocket Lake will all default to PCIe 4.0 with 4.0 GPUs (RDNA, RDNA 2, Ampere) meaning that any BIOS reset will require the user to either disassemble the build to install the GPU directly into the slot, or install a temporary 3.0 GPU just to get into the BIOS and set the link speed to 3.0... that's not the kind of troubleshooting you can expect from the average user. I foresee significant RMA issues from this.
Marvelm
232
106
Not exactly true, I'm also using a case with a PCI-e 3.0 riser with a 3060Ti and a Zen 2 CPU and it does boot without any issues BEFORE you install the drivers allowing you to easily change to PCIe 3.0 in the bios. The fact it defaults to PCIe 4.0 doesn't mean it won't display anything.
Reactions: DrHudacris
2,195
2,212
... BIOS resets don't only happen before driver installation, do they? I would also say that that is the case where disassembly is the least annoying - if GPU drivers aren't yet installed, the PC is likely to just have been built, after all. A BIOS reset months into regular use of the PC would be another matter entirely. Also, there have been quite a few reports of people here having to disassemble their systems for this specific reason. You might also be lucky enough for your riser to work (even intermittently) at 4.0 speeds, enough to get into the BIOS - but not all risers will do so. YMMV, but just because you've dodged this bullet, don't expect everyone else to do so.
Marvelm
232
106
Yeah, you're right, I meant right after assembly mostly. On the other hand, PCIe 4.0 risers are still quite expensive and we can't really expect them to be supplied with a 120$ case.
2,195
2,212
as that doesn't actually alleviate the problem. Arguably it does the opposite, as it will likely be among the first mass-market cases using a riser in this situation (PCIe 4.0 GPUs and motherboards/CPUs being prevalent, but risers being expensive and rare). (Of course existing mass-market riser-equipped cases like the NZXT H1 can cause exactly the same issues.) Given the level of technical knowledge required to even identify this issue, let alone work around it, it could potentially cause major issues with high RMA volumes and frustrated users.
Reactions: FrederickM
Marvelm
232
106
I mean, I guess? But what do you suggest instead? Not make cases that use risers at times when standards are changing? Seems rather excessive. There are tons of cases using risers and they will all face the same problems, it's just the nature of risers, they add another part which might cause problems and require troubleshooting.
tinyitx
2,273
2,334
When issue arises, I do not think an average user will RMA the case (Mesh-Licious or other cases). An average joe would probably suspect a faulty motherboard or graphics card.
Anyway, maybe, this issue should be put in detail in the FAQ. Additionally, maybe, a note be put in the User Manual. Or better, have a separate info sheet supplied with the PCIe 3.0 cable.
PS
How do you pronounce SSUPD? And my actual first thought sounded too much like 'stupid'.
BRSxIgnition
373
525
PS
This is why something like the 'SPD' would probably be a better abbreviation, along with this case just being called the Mesh.
'Hey, I finally got the SPD Mesh 1.' sounds so much better than 'Hey I finally got the sunny side up meshlicious.' (At least to me)
The latter sounds like you should be put in an institution.
Either way, looks really good from OT's video - just not sure how the cable was decided on. It's not HDMI 2.1 from what I can tell, and most monitors would need display port 1.4, so many who get this case will either need to buy a new 90° cable or adapter.
Shinken1
90
95
Might be difficult finding a 90degree display port adapter that supports DSC for my Samsung G9.
I like the white version
Revenant
Revenant Tech
1,741
2,858
Love the case. I am concerned about getting an HDMI 2.1 right angle adapter, and a DisplayPort 1.4 right angle adapter. I use both at the same time because I have an ultra wide monitor on my desk, and my PC also hooked up to an LG CX.
2,195
2,212
PS
They pronounce it Sunny Side Up in the video above, though ... where is the D in that? Can't say I get it, nor that I like the branding, but it's not like that matters much. Keeping the meshlicious name, though? I guess it's unique, but it's a poor choice IMO. Hard to say, doesn't sound good ... meh.
As for the average user not RMAing the case for that - not initially at least, I agree there. The issue then becomes them having a never-ending series of issues, never figuring out what is their problem, resulting in tons of frustration. Which will then be directed at the case once/if they actually figure this out. Unless they just sell it and move on, I guess.
The point being: this ins't a huge issue currently, but it is going to be one in 2021. There should at least be an option for a PCIe 4.0 compatible riser.
ZivZulander
50
86
Case looks great! Will get one as soon as I can (fantastic that it's mainstream, as I'm not really inclined to jump through hoops, especially with other parts also being so hard to get these days).
Very important question, though: is it "Meshilicious" (Optimum Tech ) or specifically "Meshlicious"/"Mesh-licious"? 🤔
Reactions: Valantar
2,719
2,854
If you look at the Accessory page for ssupd they have both the HDMI 2.1 and DP 1.4 right angle cables.
Reactions: thelaughingman
