Status
Version 2 (July 2019)
Customer Builds
- June 4, 2021 - This batch marks the end of production for the foreseeable future. If you'd like to produce your own L5, please feel free to use the CAD files provided under Resources. I will post here if production resumes.
- Front to back cooling (positive pressure, fans blowing into case)
- Removable front dual 80 mm fan mount
- CPU vent (120 mm)
- External PSU support reduces heat, noise, and wires
- Motherboard rear cutout
- Dual low profile expansion slots
- Black anodized aluminum power switch (16 mm anti-vandal)
- Adhesive case feet
- Supports vertical or horizontal orientation
- Aluminum construction with stainless steel threaded inserts
- Powder coat finish
- Dimensions: 225 x 216 x 94 mm
- Weight: 0.89 kg
- Made in Canada
- Motherboard: Mini-ITX
- CPU Cooler: Top down style
- Maximum clearance to side panel: ~72 mm
- Noctua NH-L9i
- Noctua NH-L12S
- Cryorig C7
- Scythe SCSK-2000
- Silverstone AR05, AR06
- Thermolab LP53
- Arctic Alpine Passive
- Alpenföhn Black Ridge (APU only)
- Other CPU coolers under 70 mm in height
- Fans: 2x 80x80x25 mm
- PSU Support: External AC power supply with plug-in DC-ATX board
- G-Unique Arch Daemon 200W plus (12V)
- Mini-box.com PicoPSU 150W/160W (12V)
- J-Hack ONE2 Plugin 160W (12V)
- HDPLEX 200W DC-ATX (16-24V)
- According to HDPLEX, the front heatsink may be removed with direct airflow to the DC-ATX
- Storage: M.2 recommended. Three different mounting locations for 2.5 inch storage:
- 1 x top (7.5 mm max height)
- 1 x front (in place of front case fans)
- 3 x bottom (in place of graphics card)
- Expansion Slots: Dual low profile (half height)
- Inside front width: 86mm
- Inside front height (usable, without fan mount): 204mm
- Motherboard to fan mount: 40mm
- Motherboard to inside front (without fan mount): 46mm
- Motherboard to bottom flange: 30mm
- Motherboard to bottom side panel: 32.5mm
- Motherboard to top flange: 7.7mm
- M3 x 6mm Flat Head Phillips (case screws, #31490 at Fastener Express)
- M3 x 6mm Pan Head Phillips (expansion ports, #31542 at Fastener Express)
- 6-32 x 1/4" Pan Head Phillips (motherboard, #32040 at Fastener Express)
- M2.5 x 8mm Pan Head Phillips Self Tapping (Mini DIN connector screws, ebay)
Customer Builds
