I plan to build this as soon as my case arrives. I can see myself and have been made aware that there will be airflow problems so I plan to mod the case but I'm not sure what fan or how many fans to add or what to do about GPU ventilation.
I plan to cut a hole up top with a hole saw for a 120mm fan for exhaust, how will that affect the cpu and psu facing each other, what is the best orientation for cpu/psu
Will an additional 120mm or 92mm in front of the case as intake improve things along with the 120mm fan up top for exhaust?
I've also seen some advice on these forums about removing the gpu shroud and fitting a slim case fan underneath and use a cable adapter so the gpu regulates the fan
Lastly, is the AXP-100 full copper the best low profile cooler under 60mm?
