My first mini ITX build. I chose the Lian Li based on convenience and it was on sale
Parts:
Case:
1. Lian Li PC-TU200B mITX
PSU:
1. Corsair SF600
Motherboard:
1. ASRock Fatal1ty X370 AM4 mITX
CPU:
1. Ryzen 1700X
SSD:
1. Samsung 960 EVO m.2 nvme 500Gb
RAM:
1. G.Skill TridentZ DDR4 2400 16Gbx2
- CAS 15-15-15-35, 1.2V
GPU:
1. Radeon Fury
Cooling:
1. Noctua NF-A14 iPPC-3000 PWM
2. Swiftech H140-X AIO
3. Noctua NF-A4x20 PWM
4. Noctua NF-A4x10 PWM
Keyboard/Mouse:
1. Logitech K750
2. Razer Orochi
Was trying to fit all these into the case...will need to mod a bit.
1. Gutted the internals and removed the HD bay. Then added rubber spacers to feet.
2. Took out the ODD bay and mod it to fit the SF600. Also cut out the back MB plate to make room for m.2 heatsink. Cut the GPU support bar that came with the case and remount it on bottom of case.
3. Was planning to add Noctua 40mmx10mm fan on back to cool the m.2 heatsink, however, the heatsink was too thick and could not fit. Will look for lower profile heatsink in the future and drill some holes into the back side panel.
4. In goes the MB, GPU, and the front 140mm with CPU radiator.
5. How it looks after a little cable management.
6. And...turned on.
Future project will be to add a tempered glass to the front side panel. I already added a silicone sleeve to the latch that opens the side panel to cushion the glass.
I will install OS and see how much I can OC this little guy.
Cheers,
Du
![](/forum/proxy.php?image=http%3A%2F%2Ffiles.overclock.net%2Fimages%2Fsmilies%2Frolleyes.gif&hash=9213d99bc0ee5afd55e2fb6ec01e5fec)
Parts:
Case:
PSU:
1. Corsair SF600
Motherboard:
CPU:
1. Ryzen 1700X
SSD:
RAM:
GPU:
1. Radeon Fury
Cooling:
Keyboard/Mouse:
1. Logitech K750
2. Razer Orochi
6. And...turned on.
Cheers,
Du
