Lian Li/DAN A4-H2O
Revenant
Revenant Tech
1,747
2,862
Same look for sure :)
It would likely be a bit shorter since you don’t need the radiator space. Alternatively, you can probably just use the same cooling methods as the original A4-SFX for air cooling.
Reactions: ALEX9
ALEX9
Not really. A4 offers quite limited support in my view. At least 67mm like the Ghost S1.
Reactions: NinoPecorino
Revenant
Revenant Tech
1,747
2,862
Oh. I see what you’re getting at. I think Dan would have to widen it quiet a bit, or eliminate a PCIE slot. He does have the C4 though which has more traditional air cooling setup.
WillM1ku
I wonder if it is possible to fit in a ROG STRIX 30XX in this case, which is 319.8mm very very very close to the 320mm limit.
Revenant
Revenant Tech
1,747
2,862
Dan,
Can you take a picture of this next to C4 and A4 cases?
TheRealGlutenbob
30
any new images to share? Watching the Lian Li expo video, I want to see what the top of the case looks like now with the adjusted push-pin design.
