I would love to see these too!A-W-E-S-O-M-E case!
Do you happen to have any photos of the A4-H2O next to the all time classic DAN A4?
It's off already. Have you enabled anti-aliasing by any chance?
Do you know custom cable lengths are ideal for the PSU for the CPU/mobo/GPU? Thanks!
Thank you sir. Did you apply any undervolt for the test? Did you replace thermal pads to the FE card?yes x8, 2,5 resolution Ultra settings
No because this depends on the motherboard and GPU you use.
No i rund the RTX 3080FE and 3900x with default settings. Sry I have no 3080 Ti in my hands.Thank you sir. Did you apply any undervolt for the test? Did you replace thermal pads to the FE card?
Also, wherever possibile, could you test it with a 3080Ti FE which runs way hotter than a 3080 FE despite having the exact same heatshink design. It would be great so I know that the H20 can support my system quietly.
It's been redesigned to fit rads with these dimensions: 133x280x30 (WxLxH)A few months ago, dan said rads up to 132mm wide are supported. Has that changed with the latest iterations of the design ?
I'm looking to fit a black ice gts240 which is listed as 133mm wide, so I'm wondering if it would fit by any chance
240 or 280?It's been redesigned to fit rads with these dimensions: 133x280x30 (WxLxH)
280 in total length, 240 wouldn't be enough to fit typical "240" rads because they extend passed the fans240 or 280?
Thanks280 in total length, 240 wouldn't be enough to fit typical "240" rads because they extend passed the fans
Man this is exciting! Can't wait Dan!Mark the 09. Feb in your calendar![]()
