Lian Li/DAN A4-H2O
dondan
DAN Cases
1,981
8,392
Volaris
Would it be possible to fit a t30 with a 27mm rad on the psu with a normal noctua 25mm on the other side.
Aegyuptus
I understand that samples have been sent out and have been eagerly checking the various youtube channels each day to see if they put the review up-- alas, not yet. Do you know if the samples have arrived yet? And if so, is there a specific date that the various youtubers have been told to wait before posting their case review (e.g wait until 2nd week of January) so that I can stop checking daily?
Also, I know the release date is expected to be the second half of January-- anything more specific than that? Such as "week three"?
dondan
DAN Cases
1,981
8,392
Has the the release date been announced?
Preorder will start on 9th Feb 2022 for Newegg, Caseking and OverclockersUK.
Max height is 55-56mm in this area. It could fit if you install the radiator and fan combo without the top mounting plate (see manual)
dondan
DAN Cases
1,981
8,392
Here are high quality production pictures:
Pictures
Clarin_D
Hey Dan, have you/Lian Li compatibility-tested MSI Trio 30 series cards? Specs say 323 mm so literally just 1 mm bigger than what's listed as compatible here so I wonder if it'll just about squeeze in
dondan
DAN Cases
1,981
8,392
Reactions: Clarin_D
ludalex
Will it fit comfortably and will there be enough space in between for good thermals with the standoff configurations for a 3090 FE?
smathev
Hi Dan.
Excited about the upcoming release of the A4 H2O. Can't wait to see the reviews :)
So, currently thinking about the A4 H2O, the C4 SFX and the GEEEK M5. I know you can't speak for your competitors, but between the A4 H2O and the M5 the dimensions are similar
  • Geeek M5: (340x140x223mm )
  • A4 H2O: (326x140x244mm)
In the M5 they claim you can have an AIO in the top of the case, and slim case fans in the bottom of the case.
Are there any options for bottom fans in the A4 H2O?
Thanks in advance!
dondan
DAN Cases
1,981
8,392
@smathev:
Is is not possible to install bottom fans on the A4-H2O.
On a sandwich style case like the A4-H2O there is no need for bottom fans. These fans would just add noise but no real benifit. Furthermore it would require much higher case feets of minimum 10-15mm to be effective at all.
Btw on the M5 you have to decide a thin AIO with thin FANs like in the T1 OR bottom fans. You cant install bottom fans + AIO.
