Lian Li/DAN A4-H2O
GucksTV
257
516
www.youtube.com
Update:
- My part on the manual is done (here is a preview)
- Final review samples are in the production
- Releasedate should be in January 2022
Regards
Daniel
As I am currently figuring out my hardware for a custom loop in your case, can you confirm the height for the CPU cooler? I am wondering if the Barrow LRC 2.0 will fit or the Alphacool Eisbaer LT Solo will be the only option for a Custom Loop? :) Kind regards
BeerNsoup
205
149
As a fan of traditional layouts I'm kinda sad that this design aesthetic is now a sandwich exclusive vs the early c4 designs. Regardless this looks like the typical excellent work we've come to expect from @dondan and I'm sure it will make a lot of people happy. Browsing the forums I've gotta say... Dan, you've been very busy. 2022 looks like it'll be a big year for you!
Reactions: dondan
ZeroDividesByYOU
Update:
Review samples are shipped out to Linus, Optimum, Hardwarecanucks, Dave2d and Bitwit.
Later we will send out more samples to smaller channels and text based tech review sites.
Hey Dan! Manual looks great! Love the CAD work in it. Also the model you used was my exact 3080 Ti that I just got so I'm glad I don't have to worry about fitment!!!!
Anyway, I saw that ETA is January, do we know if it's going to be late January? That would be my assumption, and then receiving the case in mid Feb. But I'd love to hear it from you if you know.
Skripka
Cat-Dog Perch Manager
May 18, 2020
519
636
I do not need another case.
(repeat anything enough and maybe you start to believe it)
ZeroDividesByYOU
I don't need another case.
I'd need another case.
I need another case.
I NEED ANOTHER CASE
dondan
1,970
8,311
Intel Socket 1700 example hardware config:
Here is a list of limitations that you have to keep in mind for your A4-H2O build:
- max RAM height 45mm (AIO tubes has to be above RAM)
- max GPU length 321mm
- max AIO pump height 55mm
- better use SFX instead of SFX-L for more easy wire management
aaronthelegend
@dondan
Hello! Merry Christmas!
I was just wondering if you have tested whether if the EK 240mm basic will fit the Dan a4 H2O
The pump block height specification is 53mm, but some say it is 57.5mm
Thanks in advance!
scatterforce
405
314
Is it possible to flip the front panel, such that the IO is on the right instead of the left? I keep my PC on the left side of my desk, and the IO is inconvenient for that.
