If it outperforms the L9i and LP53 by a significant margin (I can't imagine it won't)
What makes you think that your heatsink/fan combo out-performs the L9i? We know Noctua puts ridiculous amounts of R&D into their products, so if there was an easy way to improve performance significantly, you'd think they'd have already done it.
A full copper heatsink will outperform any aluminium equivalent, and more surface area outperforms less surface area.
Under otherwise equal conditions. Depending on how the additional surface area is achieved, a cooler with more surface area could actually perform worse than one with less. Just spacing the fins tighter together might not help depending on the fan that's used.
I know that copper is in general a better heat conductor than aluminium, but none of us know how much of a bottleneck the heat conductivity of the fin material actually is, and the heat radiation properties of copper and aluminium are very similar.
Don't get me wrong, I'd choose this heatsink over the L9i anytime if it really is better, it just doesn't seem realistic to me that one guys first ever heatsink could easily outperform the competing product of a company that has over a decade of experience in making nothing but heatsinks.
From the reading I've done, this sounds like more of an urban myth than fact. If you have evidence to the contrary, I'd love to hear it. Also the LP53 vs L9i performance comparison kind of seals the deal for me.
Copper is roughly twice as good at conducting heat compared to aluminum, for what it's worth.
Yeah that sounds about right. I've actually heard that aluminum is actually better at transferring heat to air than copper and that the holy grail of coolers (short of using silver) is having aluminum coated copper fins. Can anyone confirm this?
This sounds right to my pea-brain. Aluminum should allow the heat to GTFO faster as, since its density is much lower (check out table here), it lacks the ability to store the heat as efficiently as copper. So this seems like a perfect idea, better conductivity with copper for heat transfer and aluminum to let it go, let it go...
Silver, interestingly, has a slightly better heat conductivity value than copper (although not by the same margin as Al. vs Cu.) however its density is still quite a bit higher than copper - meaning it would store the heat better and would require more force to remove. So - the holy grail may well be silver fins coated in aluminum (or aluminium, hehe).
Although, from what I know - Al. coated Cu. seems like it would be the best (and most realistic) as you say - at least following thermal rules...
I dont have the article link any more but i do remember a while back that noctua said (something to the effect of) the main reason their not doing full copper or anything crazy isnt so much because there isnt a cooling benefit or a market for it but because of the higher production cost and sticker price vs their target price and sales targets. I guess they know who they want to sell too and how much they can charge to sell to as many of those people as possible
How did you get DeepCool to be an OEM for you?Thanks to all of you, that made things much clearer! I didn't know the LP53 was performing so much better than the L9i, that's a very encouraging data point to have.
Also very good point about Noctua optimizing their heatsinks for HTPCs and thus noise rather than pure performance, I didn't consider that.
That's good to know! I tried to find out why noctua didn't use copper, but gave up after a while. Another thing about copper might be that it clashes with their already unusual colour scheme, so they'd have to use nickel-plated copper or something like that, which would make the heatsinks even more expensive.
Man... I got to get me some of those, they never even return my emails.Connections ; )
