JP Artisan present
Cable Management Pictures
Advent Series is a small desktop ITX computer enclosure. With form over function in mind, this case is designed with a whole piece of 2mm aluminium sheet as the main housing (Shell). The case is not breaking any record for smallest or quietest case. It is simply a bonafida solid case with minimalist design and construction.
Dimension wise (L) 301mm x (H) 285mm, (W) 165mm
Configuration Layouts
Supports:
Build logs
Noctua L9i Low Profile CPU Cooler Build
Status
29/10/2016
And I am back, see the latest post for update
10/08/2016
Work is taking a much of my time at the moment, I do apologise for the late replies on the emails. As a side note, shipping for USA is more than half of the cost of the case if anyone is wondering.
FAQ
A series is now officially called Advent Series
1. What is JP Artisan?
We are from Melbourne, Australia. Website is live
www.jp-artisan.com
2. We still have some cases left from this run
PM if you are interested or email at sales@jp-artisan.com
3. What is the slot next to the power button and USB ports?
The slot is for attaching a metal hook for hanging a headphone, the hook is still an idea.
Supports:
- ITX motherboard
- SFX, SFX-L PSU
- 2 pci expansion slot, easily support dual slot graphic card up to 10.6 inch in length. It can fit tall graphic card such as the ASUS GTX 970 Strix Series but its not recommended due to ease of installation.
- 2 x 3.5 inch HDD and 1 x 2.5 inch SSD on a removal HDD storage bay.
- Low Profile CPU cooler (Noctua L9i or similar height)
- 120mm AIO support, can support two 120mm AIO when mounted in the correct position and depends on the radiator dimensions (Antec Kuhler 620)
- 240mm AIO support, supports up to 38mm thick radiator (Corsair Hydro 105), HDD storage Bay and front panel USB 3.0 cabling must be removed when using this configuration.
Build logs
Status
29/10/2016
10/08/2016
Design Notes
Work in Progress
Thermal Notes
I managed to compile the thermal results of the 3 configuration builds into one data table. The load test are from playing BF4. I don't like synthetic test as it doesn't show real world usage.
Personally, I like the 120mm AIO configuration because it hits the sweet point of cooling sufficiency. I like to overclock my CPU because
1. I can do it without any extra effort
2. I'm Asian. I expect every penny worth from a Z chipset and K series Intel CPU .
I can still retain my front panel USB 3.0 connectivity and the HDD bay which is a big plus compared to 240 AIO. I noticed that the pumping noise is more quieter on the 120mm AIO as well. I don't mind the noise during gaming as I use headphone. Case fan noise can be easily reduce if you don't overclock the CPU or GPU. I really wished Noctua L9i can handled mild OC but it is literally fighting for its life. The fan has to compete with the SFX and the case fans.
On the topic of airflow
Even before the initial sheet metal prototype was conceived. I made some mock-up of the case using corrugated plastic cardboard to see if there is any major flaw of airflow. After many unscientific testing, there weren't any issues with the design. Testing include raised feet, more vents on the back side etc.
Work in Progress
Thermal Notes
FAQ
www.jp-artisan.com
