Prototype Introducing the Chimera CX2
garousaitama
Hi, everyone, I'm assuming there are people here who are curious about the project, but also those who have come here at the end of a long search for the ultimate small form factor PC:
  • something small (for me, I want to be able to fit it into a carry-on that meets any airline's requirements. 20L+ is fine as long as this requirement is met.) edit: my bad, just noticed that one of the dimensions is too large to meet this requirement. I might be fine with that, don't really fly with my build anymore...
  • fits 170mm CPU air coolers
  • fits the largest GPU's (4 slot monstrosities, 320mm long. I'm thinking of the Rajintek Morpheus)
  • uses ATX PSU's while still supporting all of the above
  • and can run super quiet with top end components because cooling is amazing.
    It'd be the final case you'd ever need. It'd also have room for things like fan controllers, 2.5" SSD's (and maybe one to two 3.5" SSD's while we wait for SSD's to get cheaper). I'm getting the sense that the CX2 requires compromise if you want to use ATX PSU's, but maybe I'd be willing to make the switch to SFX just to use this case. Reviewing the list above, do you think all of those things can be achieved with this case? Basically, an air-cooled monstrosity.
Reactions: yosvos and sn0man
Dazr87
66
oh hey i think i found your build thread o_o
okay first off before i swear, i think i wouldn't need to worry as much as i should now o_o
now: damn, your photo with the top cover off solved a lot of my clearance queries O_O
just one more though: how thick is the fan in the center that came with the DRP4? I might switch that out for a 25mm thick fan (maybe +2mm total because rubber pads)
damn thats a tight fit! i like it
race2c
31
Between this and the TI, I am excited for the future of these SFF cases. Hmmm. Two cases/builds in my future, quite possibly.
Jerdz
44
1. Can SFX PSU's be mounted on the top or bottom front?
2. Will this support aftermarket vertical mounts?
3. Can I see a render of Vertically mounted gpu + psu placed on the top front?
Thanks!
VegetableStu
1,949
2,619
might need confirmation from the creators (they have moved the prototype to places by hand quite some time earlier), but from what i can google for under-seat stowage dimensions I think it might be able to fit there o_o
sn0man
51
Pretty Jazzed about this case as a destination for my wife's computer. I really like that it supports more standard air coolers and also ATX boards. Any new updates on it?
