Prototype Introducing the Chimera CX2
thekeith
Definitely going to get one of these to make a hell of a hack pro, hopefully with no handle.
Likely build will be:
  • ATX motherboard
  • i9-9900K
  • Noctua cooler
  • 64GB ram
  • NVME SSD (hopefully PCI Gen 4)
  • TBD AMD graphics card
I'm also considering water cooling, but again depends on support in OpenCore. I've also considered doing my own CPU & GPU coolers with longer heat pipes to put the coolers on the front of the case.
sn0man
51
I'm sort of sad that the general consensus is that a handle is not wanted.
I would personally get a lot of utility out of it...
I like the concept of the handle (and would also use it alot), but personally would be better served by a Cerberus-style permanent handle.
Windfall
2,117
1,584
You're probably right, but the hideaway handle looks so slick....
Reminds me of the G4 Cube in a way.
Reactions: sn0man
VegetableStu
1,949
2,619
not me, i might need a handle too ,_,
EDIT: i mean i'm not with the general consensus. dammit clarity
Reactions: Windfall
Kit
163
75
I dont see the point of a handle, you wouldnt be able to carry a monitor/case...etc at once anyway for any distance and itd be safer/easier to carry the case with two hands. If mobility is key there are plenty of power laptops that can run external full gpu these days.
I would rather the hardware inside was cooler and more stable with 2x120/140 fans in the top.
Reactions: riba2233
Windfall
2,117
1,584
You can carry a case in one hand and a monitor in the other easily.
My cousin does it with his Cerberus X and a 27" monitor.
I fail to understand how someone couldn't handle that.
Reactions: sn0man and chyll2
race2c
31
Personally, I have no use for the handle due to the case/computer not being transported. Plus more than likely, if I am moving a computer, probably going to use two hands.
Reactions: Windfall
Kit
163
75
If you actually bothered to read what I typed you'd have understood "for any distance" ment that you CAN carry both but not for a long way.
Jeez.
Windfall
2,117
1,584
Jeez.
I'm sorry if I caused any annoyance. I did read, and I did understand.
A 3D printed handle on the screen, and the included Cerberus handle.
With that, you can carry them for a while.
Personally, I don't know anyone that takes their PC on a 2-mile hike.
Kit
163
75
Exactly... you carry PC equipment for short distances... hence why a handle is generally redundant... ironically if you actually needed regularly carry it for 2 miles it might have some more value.
Windfall
2,117
1,584
Exactly... you carry PC equipment for short distances... hence why a handle is generally redundant... ironically if you actually needed regularly carry it for 2 miles it might have some value.
Yes, and you were saying you would rather carry your PC two handed. So what am I to do about my monitor?
"I dont see the point of a handle, you wouldnt be able to carry a monitor/case...etc at once anyway"
Yes, you can carry a monitor and a case at the same time if you have a handle. Hence why I want one.
@PlayfulPhoenix any chance of a swappable top panel?
(Could just message you on discord but too lazy XD)
Reactions: sn0man
Kit
163
75
? I give up...
Reactions: Windfall
thekeith
I totally get the handle would be nice, just would be better if it wasn't so intrusive into the case. If it wasn't blocking the VRM heat sink I'd be fine with it, but would prefer a clean top on the case. Maybe best as an optional feature.
Reactions: sn0man
YoRHa Edo
Any idea who is going to manufacture this? Lian Li in Taiwan or some other company based in the mainland?
