riba2233 submitted a new resource:
Internal USB 3.0 cable dual - Standard internal 19pin usb 3.0 cable
Standard internal USB 3.0 19pin or 20pin cable for connecting front panel usb ports to motherboard.
Dimensions are accurate, you can use it for your PC case design and also feel free to use it for your renders. I have measured real unit with digital calipers.
It is mounted to case with two M3 threads.
