Hello,
I'm looking around for a case that I can use in this space:
and that can handle high-end components (2080ti, Ryzen 3700x).
It seems that the following might be decent options and I'm wondering if they would be able to cool the mentioned components adequately (no thermal throttling)
Fractal Design Node 304
Lian Li Q50
Cougar QBX
I'm leaning towards the Cougar QBX because it supports the largest amount of fans but it is not designed to be used horizontally necessarily and I'm wondering if attaching 20mm 3rd party feet would be possible and might even benefit GPU temps some.
I'd appreciate any input on the cases I mentioned or ones I might have missed in my search. Thank you for your consideration!
Lian Li Q50
Cougar QBX
