Power Supply Help to choose power supply for a very small case
es2305
Hello everyone, I am a tech apassionated person like a lot of you and for a hobbie project I wanted to build a small form factor computer, but I have two issues, 1: I am not sure if everything will fit into the case, and 2: by choosing the Mini Plug Type DC PSU Module and AC/DC power supply Adapter brick.
This is the first time that I build a very small PC, I have experience in building PCs of Micro-ATX and ATX size.
I wanted if possible to buy the psu things to the same seller of the case, here are the options:
https://realan.en.alibaba.com/productgrouplist-212910832/Power_Supply.html
The most powerfull ones that I found are these (but I could be wrong):
Realan LR-1108-150W12VDC 150W Mini Plug Type DC Power Supply Module
https://realan.en.alibaba.com/produ...0W_Mini_Plug_Type_DC_Power_Supply_Module.html
DC 12Volt 10Amp 120w AC power supply Adapter
https://realan.en.alibaba.com/produ...2Volt_10Amp_120w_AC_power_supply_Adapter.html
----------------COMPONENTS:----------------
Motherboard
: GIGABYTE GA-AB350-Gaming WIFI (RGB LED will be deactivated)
https://www.amazon.com/dp/B073PWKSP6/?tag=theminutiae-20
CPU: AMD Ryzen 3 2200G
https://www.amazon.com/AMD-Ryzen-Processor-Radeon-Graphics/dp/B079D3DBNM
CPU Cooler: Noctua NH-L9a AM4
Total Height: 37mm
https://www.amazon.com/dp/B075SG1T3X/?tag=theminutiae-20
RAM: Corsair LPX 8GB (2 x 4GB) DDR4 2666MHz C16 memory kit
https://www.amazon.com/Corsair-Vengeance-2666MHz-Desktop-Memory/dp/B0123ZB70Q
Case: E-H44U
Dimension: 200(W)*44 (H)*200(D) mm
http://www.minicase.net/product_E-H44U.html
THANKS A LOT, your help will make my project possible!!!!
