Power Supply Need help choosing AC Adapter for PicoPSU/Streacom F7C ALPHA Case
vlad1966
46
26
OK, full disclosure up front: I'm not a genius when it comes to power. Basically, I know Volts x Amps = Watts, but that's about it. I used to just buy the best affordable ATX & later SFX power supplies for your "standard" affordable Mini ITX cases & called it a day.
However, I bought a F7C Alpha case a few months back & loved it, but messed it up by drilling out the hole for the AC connector, since I wanted to use a 192W brick from this kit that I bought (requires a large 4-pin DIN connector):
http://www.mini-box.com/picoPSU-160-XT-192W-Adapter-Power-Kit
I'd like to get another one of these cases & re-use if possible (I can buy something else if recommended) the 160W PicoPSU I bought from the above mini-box link, but this time WON'T be drilling out the hole for the AC connector (I believe the opening takes a 5.5 x 2.5mm DC Jack. Problem is, I'd like to build a decently powerful system in the F7C Alpha case using the 160W (200W max) PicoPSU, and most Higher-power AC Adapters have the larger 4-pin DIN plug. The system I'd like to use: Ryzen 5 2400G, NVME SSD, 2 or 3 SATA SSD's, no optical drive, 10Gbit Intel X540 NIC (maybe swap this at some point for a Quadro P1000 vid card).
So, considering the above, what kind of AC Adapter could I get? Would the popular Dell 330 Watt AC Adapter work?
https://www.amazon.com/dp/B00CGA5JQM/?tag=theminutiae-20
It seems to include the right kind of 5.5 x 2.5mm jack, but it's 19.5V 16.9A. Would that pose any problems to the 160W PicoPSU I already have?
Or would something like this work:
https://www.amazon.com/dp/B07GPBGSQZ/?tag=theminutiae-20
Any suggestions are welcome.
Thanks!
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
Thanks!
I recommend using the minibox to ensure you have the compatible hookups.
Also the dell is not compatible because it is 19V.
robbee
n3rdware
760
1,099
20A on a 5.5mm barrel connector? I'd be very carefull with that, but I'm sure @Thehack can provide better feedback.
vlad1966
46
26
Indeed. Most 5.5mm barrels are limited to 10A. So if you want 120W you'd need a 4pin one. Minibox website sells a 192W one that is compatible with their picopsu.
I already have the 192W AC Adapter (4-pin DIN) from Minibox, but the Streacom F7C case only supports a 5.5mm barrel. Would I be able to use a 4-pin DIN-to-5.5mm barrel adapter ?
Stevo_
449
304
How much power does your present build use? Maybe list components. A 4-pin din to 5.5 barrel adapter may work if you can find one if you're below max spec on it.
vlad1966
46
26
Hey Stevo_
My current build will most likely be sold. It has a Micro ATX mobo & I want to go back to Mini ITX. The rest is: i3-8100, 16GB 2400 RAM, Radeon RX 570, 500GB Samsung 970 NVME, 256GB Samsung 960 NVME, 2 SATA SSDs, SF600 SFX PSU.
I'm sort of undecided about the system that will replace it - most likely Ryzen 5 2400 APU or i5-8400 or i7-8700T, Mini ITX mobo, & rest of components will be same, except for the vid card (none if I go Ryzen 5 2400, or LP RX 560/LP GTX 1050Ti If I stay Intel) and the PSU will go too.
Thanks
Stevo_
449
304
Yeah, I should have said target build, that looks fine for 120W even 8700T with the LP GPUs. I think the biggest problem will be finding an adapter for 4-pin mini-din to the barrel style, probably need to make your own short cable, those parts are certainly available. The mini-DIN panel mounts really require a drill press to do cleanly and have never seen a screw-on style that would allow just using a panel hole-punch to resize the hole.
