Hey guys, so I have been having problems with my skyreach 4 mini build for quite some time now. My screen will go black and my GPU fan speed will max out however I can still hear some audio playing. It will stay in this state until I restart the computer.
My build
CPU: i5-9600kf
CPU Cooler: Noctua LH-L9i
Motherboard: MSI MPG Z390i
Memory: Corsair Vengeance Lpx 16gbddr4-2133hz
GPU: MSI RTX 2070 AERO ITX
Storage: Sabrent Rocket 1TB NVME PCIe m.2 2280
Power supply: HDPLEX 400W HiFi DC-ATX, Dell 330W AC Adapter
Case: Skyreach 4 mini
I first started getting this problem almost the moment I built it. I couldn't figure out what it was but I disassembled to make sure all the cables and everything was in right and I still got the issue. I thought it might have been my GPU overheating but it seems to happen at low temps even around 50C. I then tried to underclock everything and the issue still occurred. So then I thought maybe The PSU just isn't powerful enough so I swapped out the 95W 9600kf for a 65W i5-9400f. Even with that CPU and putting a power limit on the GPU the issue still occurred. Then I read somewhere that someone was having the same problem and they fixed it by reapplying thermal paste to the GPU as theirs came with minimal amounts. So I did the same and I would say that there were possibly below-average amounts of thermal paste but nothing too extreme. That seemed to make the issue a little better but it stilled occurs. Now I'm starting to think again that it might be the PSU. I've heard some people say that their dell 330W AC adapter can draw up to 400W but I'm wondering if there might be something wrong with mine as I've seen people with more powerful builds than mine running with the dell external brick. At this point, I'm pretty lost on what to do just wondering if anyone had some ideas. Not issue only happens when the computer is "under load" (i put speech marks around it because the temp readings before this happens are normal and even low in some cases).
My build
CPU: i5-9600kf
