Hi Guys,
So a couple of weeks ago I build my first SFF pc, but it has been a painfull road so far.
First of the GPU I wanted to use (GPU from the Gigabyte Gamingbox 1080) made some really annoying fan noises and after trying two of them I switched to a Zotac GTX 1080 Mini today but came with this lovely coil whine.
Now I wanted to do some testing with games and for this I tryed Destiny 2. I can play the game on max settings with 200 FPS at ease (60 FPS with Vsync to reduce coil whine). But after about 5 to 10 minutes of playing my PC resets itself and sometimes but not often it just stops the game and that it.
I checked the temps, but those shouldn't be the issue I quess since CPU is at 50c and GPU at 59c, RAM, MOBO and SSD's at 40c.
Now I use the following build:
Intel core I7 8700
Noctua NH-L9I
Asus Strix Z370I ITX
Zotac GTX 1080 Mini
Samsung 960 Pro NVMe
Samsung 960 Evo NVMe
16GB G.skill Trident 3200 MHz
HDplex 400w
Dell 330w brick
Skyreach S4M
For the record:
I already tryed with stock settings in bios, but same issue. While being undervolted (CPU) by 0,15v same issue. While underclocking the GPU, it did work a bit longer but eventually same issue.
Also I checked with 2 different Dell 330w bricks.
Hope you guys might have a solution![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Intel core I7 8700
Noctua NH-L9I
Zotac GTX 1080 Mini
HDplex 400w
Dell 330w brick
Skyreach S4M
For the record:
