Current version:
Gallon v3
Height: 182mm (DC-ATX PSU); 217mm(FlexATX PSU)
Width: 98mm
Depth: 178mm
Case Volume: 3.17-3.78L
Case Weight: 200g
Total system weight 3kg (e.g.: FSP400-60FGGBA, Gigabyte GTX 1080, Noctua L9a, Asus x470-i, Ryzen 2700)
Compared to previous version:
- support for 37mm CPU cooling ( Noctua L9i/L9a)
- better cooling of GPU and MB back sides
- softer case edges
- support for DC-ATX PSU (guryhwa's Arch Deamon)
This case is for you if you:
- like to bring with you your desktop grade gaming PC when traveling (on a business trip, to college)
- have an opinion on what color and material your PC case is made from (as long as it is 3D printable![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- want to modify the case just a little bit, so it can accommodate slightly bigger GPU or CPU cooler
Gallon v3 .stl files are now available for download on my Patreon page.
https://www.patreon.com/tinycase
Gallon v3
Width: 98mm
Depth: 178mm
Case Weight: 200g
- softer case edges
Some Pictures
If you like the project please consider supporting me on my Patreon page:Previous versions:
Gallon v2.2
Height: 217,5mm
Width: 98mm
Depth: 177mm
Weight: 200g
-Easier to print
-More convenient to work with
-3.78L external volume
-support I/O shield
Free for all because of newer version available:
https://1drv.ms/u/s!AkGTXCmnUdjtk6hxs1KXdwV8qANhEw
Pictures
Case components
PC components
Almost assembled
Front view with lights
The back side (no lights)
Gallon v1
Model name is Gallon because the internal volume of the case is 3.78 liters or one US Gallon.
Here is a picture of the prototype I printed for test purposes. All measurements are in metric system. I also included a banana for scale
The test hardware is: Zalman CNPS2X, Intel i7 7700T, ASUS Z270I, Gigabyte GTX 1070 Mini ITX, Samsung EVO 500GB NVMe, Fortron FSP400-60FGGBA. None of those components were modified in any way.
The external volume of that case is 4 liters. Weight with components installed is 2.7kg.
For the past two months the shown setup has been tested extensively under synthetic and real-world load. The software used for testing was Furmark, XCOM 2. The test sessions lasted for up to 10 hours. The room temperature was kept at stable 22-24 Celsius. GPU never exceed 70 Celsius with 54% fan speed. CPU stayed below 68 Celsius under load.
https://1drv.ms/u/s!AkGTXCmnUdjtkfE1r6m4NjDe5kN9Hg
