Production Gallon PC v3: 3D printable 3.17-3.78L gaming case
ondert
298
143
Hey @wesbl I live in Italy too and used 3dhubs.com to print the orange case above. A guy from Milano printed it and it costs me about 50€ with shipping.
Great news @ZMan, I thought that you left the project before. NH-L9 support will make the case more attractive definitely. I would like to get the v3 when it is released. Can you say anything about the case volume of v3?
ZMan
69
87
1 US Gallon or 3.78L external volume with the module for internal FlexATX PSU.
Reactions: ondert
ondert
298
143
That's superb. You'll keep the same size while making more space for cpu cooler. I'm already looking forward to get it.
ZMan
69
87
@ZMan I have this 300mm riser cable, do you think could be ok for your V3 case?
no, it won't be. Because the PCIe x16 slot is pointing to the side AND the cable is too long.
In Gallon case the riser cable is attached to the chassis and play an important role in supporting the GPU. So it has to be the straight type.
Reactions: wesbl
wesbl
174
115
When I will be ready with my printer I will try to make a nicer print.
Really nice layout, especially the front hinge.
RX 570 ITX 8GB fits perfectly (170mm), also the scythe s950m (great discovery, only 14$!).
ondert
298
143
Hey @ZMan is it possible to squeeze this gpu in the case? It is 175mm. Thanks
ZMan
69
87
The case comes as a set of 3D models files. Those files can be edited to fit a 175 mm length GPU before printing. I can do that on Patreon patron request. Latest version of the case is available only to patrons anyway.
Or
You can download one of the previous versions for free (links in the first post). And edit them yourself in your favorite 3D editor.
Reactions: NinoPecorino
