Concept FormD T1 V2.0
Roen
49
I wonder how the P1 will compare to the Cooler Master NR200 in a 280 AIO + 2.5 - 3 Slot GPU configuration in terms of temps and noise.
At current time, it'd be the Arctic Liquid Freezer II 280 and the Asus 2080 Ti Strix OC that I'd be using.
Jawaiian
I'm excited for this case! I can't wait to see the internal layout and its overall size compared to the T1 (like a photo of them next to each other)
Tazpr
552
426
The fully mesh design is really striking - I think the general design principle here is super cohesive and premium. Look forward to see this develop cos I'm a bit of a suck for a vertical case haha
RickNeclaDon
Really looking forward to the vertical version of this case. I have the NZXT H1 now and while I do like it the air flow is garbage. The P1 looks incredible in both design and practicality
Reactions: Madhawk1995
Sen
40
47
sen.lol
So excited to see the prototype for the vertical orientation, it's a perfect height to fit on my bookshelf. Would be nice to finally get ditch ATX and big floor-standing cases.
Luke NK
126
116
@Wahaha360 is this possible? I've been working on this vertical layout
Twisted riser cable. Should be possible?
Motherboard in conventional position
Vertical GPU
Angled GPU adapters with cables routing towards the back where there is a bracket with all the ports
Access through back of the case in vertical layout without adding height or needing to incline the case to access IO
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Vertical GPU
Coming out next month.
Stinkybear
98
91
Vertical GPU
It's kind of how this case does it with their riser. If only it was mesh like the P1 it could have better case cooling.
Reactions: Luke NK
BRSxIgnition
373
525
Sorry if this is a stupid question, but the riser cable mentioned, or the P1?
Judging by reactions to your post, you'd think you just teased the case itself coming out next month - but based on what you said earlier, that feels a little soon?
Could you clarify which you mean?
