These parts do look quite different than prototype 1, for example
looks like the backside of the case. But now has two big threaded holes? And the powerport cutout has moved to the center.
Curious to see how what the assembled case looks like.
More likely to be for passing water-cooling tube in case of external water-cooling (which was pretty common some years ago)I’m guessing both holes in the back are for the power button; to choose the most convenient placement.
gpu: up to 3slot 314~320mmMaybe it's been called out somewhere along the thread and I've just missed it, but do we have a comprehensive spec/dimensions list somewhere? Committing rough cpu/gpu/radiator/fan height limitations to memory is fun and all, but a full picture spec sheet prior to launch would be extremely helpful. For those of us that would like to plan carefully and give our projected builds heavy consideration before the mad dash upon release. For the life of me I can't even recall if there's any space for 2.5" drives.
I remember asking waha this, and this is what they saidMore likely to be for passing water-cooling tube in case of external water-cooling (which was pretty common some years ago)
16mm Vandal Switch power hutton.
Or
Watercooling (via M16 to G1/4 adapter). Having two holes allows your to bleed the air out of the loop.
@MattyKHZ - try and keep your posts combined to a single message if you can, it fills up the page very quickly and most of them are quoting your own posts.
The finalised listing on SFF Lab will likely include much of this information as they do with the M1/A4, I think the focus is on getting things ready for shipping right now then the listing will be updated when it goes up for pre-order.
have deleted every question posed as see little point asking on here when no responses are given. I find it strange that it is known to the mm cpu aspects as stated at the very start but not gpu when one plus the other is the available space.
didnt think my questions are unreasonable about this, shipping, colour etc but as all have fell on deaf ears what is the point in this thread. We can all wait for sff labs to inform us if that is the case.
every time there is a eBay discount going it allows some of us to get bits ready for this case. Now I don’t care which I get, will wait for sff labs to inform me of those I have shown interest in or will sit back and allow users to state what will/won’t fit when the get theirs in many months time......
Yeah Louqe/Dan ones will work as the physical distances of the cables is still the same. Pslate got you covered broAny idea what custom cables will work in this case? I'm assuming any sandwich-style customs will work
Yeah Louqe/Dan ones will work as the physical distances of the cables is still the same. Pslate got you covered bro![]()
Hello
Does Seasonic Focus SGX 650 fit to this case?
SFX-L
Thank you so much!It will still fit but it will be tight. I would recommend going with the corsair 750 sfx
As long as the radiator is 25mm thick or less, it should fitWondering how flexible my cables will need to be to use my current Silverstone Nightjar 400W... So nice to have a passive PSU that's so efficient. Planning on running a slim 240mm rad. I guess if I use a slim fan on the radiator it will be fine huh?
The 20.5mm XSPC TX240 doesn’t fit though because it is too wide.As long as the radiator is 25mm thick or less, it should fit
