Has anyone heard any chance of a handle accessory option like the Sliger cases?
Sure, I get it. But with game engines and graphics APIs taking increasingly better advantage of more cores/threads, combined with high resolution gaming's GPU-bound nature, my bias is to maximally cool a monster GPU while opting for a lower TDP CPU.
With modern options like the 65W 3700X, this strategy can work really well. The days of single-threaded performance's import to gaming and VR are coming to an end, much to Intel's lament.
For those who care, here are the results for the Corsair H60 compared to my NZXT Kraken X52I would think the Corsair h60 2018 would be enough, if you can stand the bright white lights on the pump. Waha has also done some testing with the h60 2018, so you can find that in here.
My overclocked 1600 draws about 100w under a full render load if HW monitor is to be believed, about the same wattage as an overclocked 3600 (going off of GamersNexus), so when I get the h60 I can tell you how it performs if I remember
I'm dealing with M1 shipping issues atm, it's also a Holiday in Taiwan / China, will make update soon.
I googled a bit but couldn't find any testing on a Alphacool LT240 in a CPU+GPU loop. Anyone know if thats a good idea, or should I stick with getting something like the FTW3 cards with massive coolers and only using the Alphacool LT240 on my CPU
I believe waha has done some testing and found that using slim fans has little to no impact on cooling, so I wouldn't worry about that. Also I think JayzTwoCents has done some testing and found that radiators aren't affected much by the temperature of the air going through them. So imo, there's not much to worry about in that regard.You can find in youtube a channel called optimumtech and he has done a custom loop with a eisbaer solo (th block+cpu combo on the aesbaer lt240) and he has added a alphacool st30 240 rad + a EK (I believe) waterblock for his 2080 ti (reference). He said that he was going to make a video soon with the results, so it´s a matter of time. He is doing ot on a louqe though so, bigger rad and 2x full size fans, but you can draw some conclussions from his video.
edit: if you ask my opinion, you should be better with the eisbaer just for the cpu and a fat aircooled card. I guess it will be almost silent when browsing and while gaming... I don´t know really.... But that 25mm rad with small fan... trowing in there a hot card + a hot cpu (I guess) doesn´t sound like a good idea.
I´m guessing here, but if you sum up a little less air because of the fans and a litlle less heat dissipation because of the slim rad... in the end it sums up and it would be noticeable. Also two hot components in a single rad... despite the slim fans and slim rad... is a bit of a strech. Having the room to use a 3 slot graphics card, I really belive that the best way is to watercool just the cpu
It depends on your usage. A 240mm rad would be enough for a gpu + cpu provided you do not load both completely. So, for games, it would be more than enough, but you couldn't get both components at high loads at once, as you would overload the system regarding heat dissipation and the cpu would throttle. But for games? Yes, you could get very good results.
have a good source on this? it would be very nice to only have 1 radiator and 2 fans in my system...
I'd just like to look at some numbers and make up my mind![]()
Yeah you're right, I remembered it wrong. Water-cooling is better than air cooling when it comes to warmer air. This is the video I'm referencing.Ofc radiators are affected by the temperature of the air that is going through them. It is one of the biggest factors!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What do you mean source? If you are trying to COOL something how come the temperature between one thing and the other isn't relevant? In fact, the higher the temperature difference (or Delta T) between the water inside the radiator and the air, the better performance you get.
I just want to see the temps from a GPU+CPU in a 240 rad and see how well it works.
I found a bunch of posts with people asking "is a 240 rad enough for GPU+CPU" and a bunch of people answering that with "yes" and "no" but i didn't see any temps.
of course, i'm at work and havent looked exhaustively. just glances.
www.xtremerigs.net
Alphacool NexXxos ST30 280mm Radiator Review - Page 5 of 6 - ExtremeRigs.net
Alphacool NexXxos ST30 280mm Radiator Review - thermal performance compared to EK CE, XT45, UT60, Hardware Labs Nemesis GTS GTX SR2www.xtremerigs.net
Here is a 280mm alphacool 30mm rad. Push configuration at 1300 rpm fans dissipated 230 watts of heat per 10C delta. Even in a 30C ambient, I think a delta of up to 20C is accetpable, so this 280mm rad can be expected to dissipate 460 watts of heat. A 280mm radiator is 36% larger than a 240mm radiator, so an equivalent thickness 240mm radiator should be able to handle ~340 watts, less given the Eisbaer LT240s thickness of 25 mm, so lets say ~300 watts of heat. Again, will be a touch lower as we can only use one full size fan.
A stock high end GPU pulls 250 watts, a cpu maybe 100 watts (during gaming, its probably lower). So lets call it 350 watts. We've exceeded 300 watts best case scenario.
If your ambient temp is lower, lets say air conditioned environment, 20C, you've got more room, up to another 150 watts more.
Disclaimer: these calculations are extrapolations, take it with a grain of salt
