Hello guys, I decided to go full custom loop with this case. I saw a FormD T1 site and I am unable to preorder. Does anyone know when will be the next batch/preorder time?
Only w360 really knows; best you can do is subscribe to the newsletter and wait.Hello guys, I decided to go full custom loop with this case. I saw a FormD T1 site and I am unable to preorder. Does anyone know when will be the next batch/preorder time?
Sure if you want. The other is for the power button, and no second fitting is supplied. They will come as a accessory sometime in the future.
Looks really good!This was my idea!
I'm not done yet. There will also be a m.2 ssd placed under the power button cables, and next to that copper tubing with a temp sensor.
May I ask wich psu power cord are you using?This was my idea!
You mayMay I ask wich psu power cord are you using?
No it's a Coolworld radIs that a magicool G2 crossflow?
I have the same radiator and I was wondering about doing the same thing. What fittings are you using?
Actually I would REALLY want to order a silver front panel. Just the standard one supplied with the duo tone case, and I was wondering the exact same thing.with everything merges into v2, the current T1 v1.1 is being discontinued, that means we won't be able to find replacement parts in the future? like if i scratch my front panel and want to order a new panel, i won't be able to?
Hi @Wahaha360,If some % of the refund amount is lost due to exchange rate and or fees, keep the evidence and we will refund you for this loss when you place the next order.
They do have 120x17 and 360x17 as well. The 120 also comes in black now.@stanleyguan , do you know if they make a 120x17 of that radiator?
ThanksYou may
I'm using the 35cm long one, but I think it will need thicker cables for 750 watt so be aware.![]()
US $9.49 |Computer Case Verlengsnoer Power 90 Graden Elleboog Verlengsnoer Vertind Draad A4 Case Gewijd Mannelijke En Vrouwelijke Aluminium versie|Netsnoeren & Verlengsnoeren| - AliExpress
Smarter Shopping, Better Living! Aliexpress.comnl.aliexpress.com
And for the case itself you will need this
0.13US $ 15% OFF|250VAC 10A AC power socket C14 Inlet Voedingscontact Connector Plug Industriële socket Plug IEC320 C14 3Pin Panel Power Inlaat socket|Connectors| - AliExpress
