A bit messy, still need to finish cleaning up some wires in the build, trim some zip ties and add my lighting strips, but here is some shots.
I have two issues though:
1. how do I get a single slot plate to stay in place to cover the 3rd slot at the back, or should I leave it open?
2. my GPU temps seem very high, up to 98c junction temp when playing 2077 (which I get around 55fps average at 3840x1600 full ultra)
CPU sits around 70c during the gameplay which is high I assume from the GPU air venting through the radiator as CPU is only at 12% during gameplay at 4.25ghz (3950x)
with all this, like my old Dan A4, the top of the case becomes so hot you cannot hold your hand on the case for very long. does this all sound normal to everyone? or are my temps unusually high?
Full System Specs:
R9 3950x (boosts to 4.25ghz in games in Auto OC mode)
X570i - Strix (damn chipset fan is annoyingly loud, any fixes, I've seen mention of missing thermal pads, might need to check mine, worth noting though, this only started AFTER i had to force my bios to PCI gen3 due to the riser cable not supporting 4.0[i tried, but I got boot failures on 6 our fo 7 tries with it left at Auto, keen on a recommended gen4 certified riser from @W360])
64GB (2x32GB)Team group Vulcan @3200mhz (cant seem to get it up to 3600mhz without loosening timings so happy where it is)
EK 240 AIO
2x Noctua NFA12x15 chromax fans
Corsair SF600 Gold
PSlate custom unsleeved cables in black
and the newest addition, Reference model RX6900XT
Full System Specs:
EK 240 AIO
Corsair SF600 Gold
