I expect AMD to make an announcement tomorrow concerning the big Navi.
Should actually be TODAY! The tweet was sent out yesterday.
Sure but he tweeted that 15 hours ago. That would be Tuesday evening Sept 8th for him in Florida.I'm not sure, I live in Europe and it's 17:30 09-09 here. i thought this guy was situated in Miami Florida and that it's 11:30 AM 09-09 there.
Yep that's your local time for when the tweet was posted! As far as I know, the only high profile man that tweets at 2am in the US is orange and wears a wig.I don't use Twitter so i really can't say for sure but under his message it reads
2:38 a.m. · 9 sep. 2020
I assumed this was the time of posting and that the announcement will be made on the 10th.
I hope they will release a biggest Navi and are competitive with at least the 3080 possibly 90 while using less power!
I wonder how much of the gpu market will be lost to them solely by their release date if they won't release more info.
I feel like the only thing they actually have is a competitor for the 3070 that will release in Oktober.Yeah, interesting thought since Ampere ought to be relatively well distributed in the market by then. Although I also wonder whether it's a calculated risk based on possible assumptions that hardcore NVIDIA fans probably wouldn't be swayed anyhow, and those on the fence are likely already awaiting Big Navi, et al. anyhow. Still seems hella risky to me to wait that long, though. Hopefully it's worth it!
The 3070Ti is pretty much confirmed already so that won't go well.
Otherwise it makes no sense to wait this long with an announcement.
They are basically giving the market to Nvidia, and if I can I am getting a 3090.
I am expecting the 80 and 90 to be 40% and 60% better than a 2080TI with around 100% better raytracing.I'm planning to get a 3080, not because I don't believe RDNA2 has an answer to it (I think they have a true competitor to the 3080), but because of the exceptionally short PCB. That's it!
Just a little food for thought: Xbox and PS5 consoles have 2080 ti performance with less than 200W total power (that includes the CPU). And nVidia might be able to dazzle with misleading performance numbers, but 3080 is not 2x performance, its more like 70-80% over the 2080S. The leaks will start pouring out of AMD now that nVidia has made announcements. We only have until next week to get benchmarks for these beasts, and the planned "leaks" from AMD will surely be revealed.
I really trust this guy. He is extremely thorough and logical, and even reported on RTX IO a while ago. Of course AMD desktop GPUs will have something similar; after all, the consoles are already confirmed to have a similar tech!
https://noctua.at/en/nf-a12x15-pwm
vs
https://noctua.at/en/nf-a12x25-pwm/specification
airflow 94 vs 102 m³/h
quiet small difference !!
why you even bother with thicker fan.
Was kinda disappointed by the fact the host didnt realize that the monoblock wasn't at fault for having higher temps.
How much heat does a VRM give off? Can't be more than 15-20 watts unless you're doing extreme overclock. No reason for CPU temps to be that high because of VRM heat.Was kinda disappointed by the fact the host didnt realize that the monoblock wasn't at fault for having higher temps.
The monoblock was also cooling the vrm of the mobo which the alphacool CPU block did not have to do.
Hence the increase in temps. Again, host did not realize it.
You'd be surprised, here are a few sources:How much heat does a VRM give off? Can't be more than 15-20 watts unless you're doing extreme overclock. No reason for CPU temps to be that high because of VRM heat.
EKWB
LTT forum
A reddit thread
As you can see, a 100 degrees Celsius isn't exactly nothing. You'd definitely want bigger radiators, pumps and fans in general to use with a monoblock.
Especially since with every next CPU, the voltages and TDPs increase. As a result, the VRMs will work in overdrive to keep up with the CPU's demands. Some mobo manufacturers even add to their VRMs their own dedicated mini fan lately, if that makes sense.
Example:
