    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
wenyuax
60
60
120mm rad is easy, I can probably run that in push-pull with 2x 25mm thick fans so I don't think we're discussing about it here. to fit 25mm fan on 27mm thick 240mm rad you need to remove 10mm from either the fan or the rad or both, which is just not possible
@DrHudacris sanded down Scythe Kaze Flex and I think @wenyuax is going to sand down Noctua A12x25 soon.
Don't put words in my mouth lmaoooo! I'm gonna use the 17mm 240 radiator so it's only 42mm total! And I won't try the pull option (that makes it thicker because of screws) since I need the clearance to route my tube. Otherwise the top radiator will be only 1cm away from my side 280 radiator and no place to put any fitting on my top radiator!
Wait, maybe I could? If I push the side radiator to the top the clearance may be enough for the alphacool's low profile 90° fitting!
So did anyone tested whether pushing or pulling is better? And how much is the difference?
Ashenfall
57
79
Not in the T1, but here's a relatively ancient test from KitGuru
Push is ever so slightly better than pull by 1-2 degrees on both an air cooler and a radiator
wenyuax
60
60
tinyitx
2,273
2,334
Hongkong, CHINA
The idle temp for hyper 212 led. Push/pull gives 24 and push gives 23 lol.
The difference is only 1C which could be just accounted as a margin of error during the testing.
But, I think, the more likely explanation is that the reviewer did not take the ambient temp into consideration.
Looks like he first tested 'push', then 'pull, and finally 'push+pull' configurations. So, by the time he did the 3rd test, ambient air temp had risen by a degree or so.
Usually, push+pull would only give a couple degrees benefit except in certain situations like:-
a. a radiator with high fpi
b. dual towers like NH-D14
Fitchew
111
63
Moscow, Russia
Finally managed to finalize (kind of) my first water cooling build, thanks to everyone in this topic.
@fabio Mad respect for your work, it really is tight space man!
Few things to correct before calling it finished. (If it ever finishes?)
To do list;
  1. I guess I still have air pocket in the pump, since I hear running water sounds from time to time. (I guess I will get a cheap reservoir and try to push out/put more liquid with it.)
  2. Get an offset adapter or 45 degree elbow for rad entrance. Now the tube is connected directly to rad, and it has light kink.
  3. Get the pump cables sleeved.
  4. Get an NVME drive:D
  5. Although PSU cables don't bother me too much, I'll probably get custom thinner cables soon.
  6. I'm thinking about getting another 90 degree turn for the right bottom corner. (Holding on to this idea, since I might use risers to push PSU to the side cover for better cable management)
  7. Get a new gen two slot GPU so I can close the other lid☺ Hopefully with water block attached ?
Here are some shots of my case;
I would like to pay the attention of you guys that @grinny used the Sapphire Nitro+ RX 5700 XT. Like the new RTX cards, it has an air-through-heatsink design with short PCB. Besides, this card can be very hot with PL +50%.
fabio
1,885
4,325
really wish this case was 1cm taller, what was the reasoning behind not allowing 25mm fans with rad?
Well, officially the 240mm rads are not supported (apart from the LT 240 with 1 slim fan).
So, This case was designed to support 120 AIO with a 25mm fan, staying below 10 Liters, having support for 3 slots GPU, etc, and it is perfect on this!
All the rest are unsupported configurations, so, whatever we can say, it's outside the design itself!
Ashenfall
57
79
eh I wouldn't pay attention to idle temps. Load is more relevant IMO
from memory there was a design goal of certain LxWxH proportions in relation to each other while trying to stay under 10L. Increasing height by 1cm would have ruined the proportions/volume goal
also 240mm AIOs with 25mm fans was never the intended goal for the designers either. They always intended it to be for 120mm radiators only. 240mm radiators being able to fit with 15mm and 25mm thick fans was just a coincidence
Reactions: TSOF and fabio
tinyitx
2,273
2,334
Hongkong, CHINA
...This case was designed to support 120 AIO with a 25mm fan...
...They always intended it to be for 120mm radiators only...
Reflecting on this for a moment and I find it interesting.
If (just a hypothetical consideration) the T1 can actually only allow 120 AIO and absolutely no 240 whatsoever, will current owners' interest in it be greatly diminished?
How many of you guys will still buy it? There are other features, of course. But is this 240 feature (by 'coincidence and not by design) a 'must-have' feature?
fabio
1,885
4,325
Depends on your needs! With a standard Intel Wattage plan and the Actual Ryzen CPU, the max CPU power consumption are around 120/140W, and an L12S or a 120AIO are perfect for this. GPUs on Air are amazing IMO as well.
My answer is, YES, is the best case for 90% of the people!
Speedster
56
111
I don't even have an AIO in mine - Black Ridge with 92mm Noctua on the CPU, and a Gigabyte 2080 Super on air. Two Noctua 25mm fans exhausting air from the case. Works really well and not too bad on thermals or noise when the load ramps up. My interest still holds.
Ashenfall
57
79
100% will still buy
This is the only ITX case available that has mesh panels for the ideal combination of good airflow and dust/fur filtration, and supports 3 slot GPUs, that I could obtain in Australia. Out of all the SFF cases out there it ticked the most boxes for me (and I trawled through this entire list)
240 AIO compatibility was a non concern to me as I started off my build plans as a strictly air cooled build. As my research built up I slowly understood that some form of water cooling, be it AIO or custom, would be necessary to keep the temps of my desired CPU in check, and now my plan is currently a 240 AIO, and later changing to a 120mm rad CPU only custom loop
Due to the demands of the market though, there is now the FormD P1 under development, which is a similar mesh panel sandwich case which is specifically built around 240 and even 280 AIO support. However that's far from production, it's barely into the prototyping stage.
DmanX
93
82
Two questions;
1. Are the aluminum louvre style side panels still on track for end of year availability. They look awesome. Must have them.
2. In the illustrations on page 1, the two cutouts on the front... what are they? future expansion for USB 3.2 Type C and SD card reader slot?
eblvrm
I agree 100% percent regarding all air T1. I just came back from 240mm Corsair H100i + 2xA12x15 build to Noctua L9a + 2xArctic P12. I just could not stand my aio pump coil whine even at lowest setting and turbulence noise generated by slim Noctuas below top panel during load. Maybe I'm just to sensitive for this type of noise but i was not feeling comfortable after around 30 min using my PC without any music/radio playing. For my config with is mostly used for gaming - 3 slot 2070 super and undervolted 3600 paired with L9a is more than enough. In the future I'm going to buy Black Ridge for sure. It is very versatile cooler that can be used with additional 120mm slim fan in 2 slot mode for extra performance.
Reactions: ellroy80
