That's what I want to do) it will be hard to lay hoses who doesn't try doesn't winActually I think should fit if you route the inlet of the GPU on top, between the back of the radiator...
Maybe you could be lucky, but officially they don't fit. I had an Alphacool, Heatkiller, and they have different mount from the EKWB.Is the port spacing on the top of gpus standard? I have a Bykski gpu block on order and want to use that rotary fitting with it, but I can't find dimensions for it. I have seen gpu ports that are the same size openings, but spaced further apart so I think there are no guarantees. Bykski's low profile fitting selection is less than ideal.
It will fits for sure! But why a custom PCI e bracket? You can have it connected with fittings to the gpu block, like I did with my build using the 1U reservoir.This is very neat! I actually have a TX120 sitting on my desk as well as another chromax slim fan. My plan is to use DDC with 1U res in front of GPU and mount the radiator and fan to a 3D printed PCI bracket. I will need to switch pump block off of GPU and use EK block with rotary terminals (on my desk also lol).
I'm pleased to hear it won't be in vain, as already your passive radiator is showing 3-4 degrees cooler nice!
I have other cases, a lot actually. But the T1 gave me a flexibility that no others gave me! It very nice and easy built and unbuilt with this case!@fabio do you invest this much time, money and effort into every SFF case, or is the T1 just so good that you had to go all out? Either way you're a legend for all the stuff you've done with this case.
is there any chance to design a vertical stand? for a better performance and smaller area use
smallformfactor.net
Actually some seller in Taobao do sell LT240 radiator only, When I bought my LT240 I saw the option to buy the radiator only..Just a heads up, LT240 radiator will soon be available without the entire kit.
No word on the pricing just yet.
The case should not bend with the LT240.does the case still get bent at the top when use the LT240?
@Wahaha360 are there any plans for pci e 4 riser cable in the future, seeing as motherboards and gpus are moving in that direction.
I think we need to take a break from the discussion. I believe that you should silently expect a pre-order. All possible tests, questions and problems were considered. Many thanks to everyone who has T1 for your test reviews. We were all able to love this project even more.
Until 27mm will not bend.does the case still get bent at the top when use the LT240?
