I really hope to get T1 in the June order and show the results here. I think it will also be a very interesting assembly of the EK-CoolStream Classic SE 240 and xspc 240 and four fans 12x15mmDO IT! ?
I want to get the T1 to build with two full-fledged 240mm radiators, one of which will be next to the xspc tx240 graphics card
You can't have more than 1 240 in the case, read the specs, look at the builds, it is physically impossible. Not to mention your temps will suffer on your gpu because there is no room to expel hot air, your loop will heat up because of the GPU's hot air. I am not sure you thought this through.
From someone who has studied and has built a industrial version of a water loop (hospital, office building, etc) and knows a thing or two about airflow and thermodynamics you are wasting your money for degraded performance. But it's your money to waste so have fun.
I will put this adapter and as Fabio I’ll install the radiator in parallel with the video card and everything should work out fine. in theory![]()
EK-FC Terminal Rotary 90° - Black
EK-FC Terminal Rotary 90° is a replacement connecting link for any EK-FC (Full Cover) water block utilizing FC Terminal type fitting manifold.www.ekwb.com
I am curious to see your tubes routing!I will put this adapter and as Fabio I’ll install the radiator in parallel with the video card and everything should work out fine. in theory![]()
Guys, I could seem crazy but I know more or less the meaning of space optimisation (and if it is worth the effort!) - I'm an architect BTW.I Have this concept in mind since ghost s1 ?
Don't need it, I've the D5 exteriorWhat about a DC-LT also inside?![]()
Does anyone know if you can use a dual-slot gpu with a single slot expansion card? I want to use a quad-nvme PCIE single slot card to get big storage in SFF![]()
To be fair, @integer said big storage, not fast storageI think you will need a custom bifurcation riser. But sorry to say, quad nvme card will not give you the speed you are expecting. The 16x slot will be split 8+8. Your quad nvme card will only have 8 lanes to share amongst the 4 nvme cards.
The problem you will have is the dumb PCIe quad NVMe cards expect to be put in a x4x4x4x4 bifurcated slot. You will only see the first drive in a slot that's already been bifurcated to x8.
To get four working NVMe drives on a single card you'll either need a custom riser that has a PLX chip (PCIe switch) or your NVMe card will need a PLX chip that uses the x8 uplink.
My NAS has a custom riser with three physical x16 slots, electrically x8x4x4 (mobo slot is set to that bifurcation). Currently have a 1660Ti (x8) and a LSI 9202-16e card (x4). Funnily enough the LSI card is actually two 8-port controllers on one card with a PLX chip.
Gotcha. Thanks guys, @Speedster is right, big is the bigger factor. That said, this puppy shouldnt be a slouch.
HighPoint SSD7103 Ultimate NVMe Bootable RAID Solution
Simple upgrade solution for your Workstations & Servers.highpoint-tech.com
This has the PLX chip built in so no need to worry about bifurcation support.
Pair it up with a simple riser.
Gaming PCI-E 3.0 X16 Riser Cable
A 200mm PCI-e 16X flexible riser cable with EMI shielding cover, supporting PCI Express 2.0 and 3.0 applications.www.thermaltakeusa.com
Seems like it should work? What am I missing? My biggest unknown was more around will it physically fit?
How do you connect two cards with that? You'll need a x8x8 bifurcation riser. Something like https://peine-braun.net/shop/index.php?route=product/category&path=65_59![]()
Actually I think should fit if you route the inlet of the GPU on top, between the back of the radiator...I will put this adapter and as Fabio I’ll install the radiator in parallel with the video card and everything should work out fine. in theory![]()
